I have a Sony 32Gb memory stick that I bought maybe 4 months ago which I use regularly with my home PC Windows, work PC Ubuntu and Macbook. Recently I have noticed that some folders featuring images or tex files are becoming corrupted.
For example some .tex files will appear garbled and some png/eps images are no longer accessible.
When I remove the USB stick I always use the remove hardware safely options. What could be causing the corruption?
I ran the windows drive repair function once and one entire folder ended up being lost (fortunately I have a backup).
It's quite annoying though as I compile tex documents a lot and having to recreate files or images as they will no longer compile correctly is a time waster.
