Hi a question when you guys are using your soundbar and subwoofer do you use the tv speakers as well or do you shut them down and only use soundbar and sub....
try both ways see what you prefer
every ones hearing is different its what sounds best to you that matters
i have soundbar and speakers on my pc
somethings i prefer using 1 some things the other
somethings both
end of the day no right or wrong just whatever you prefer personally
My XF90 has this option too but experience says its probably useless as there will more than likely be a delay between the TV speakers and external audio therefore causing a slight and annoying echo effect.
