11 Feb 2013 at 13:42 #1 tidusjar tidusjar Soldato Joined 11 May 2011 Posts 2,901 Location Farnborough Looking to get an entry dSLR camera. Seems a good price for one of these (used). Any suggestions for any other cameras in the same range?
12 Feb 2013 at 06:07 #2 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton Would help if you gave us the price, you haven't given us enough info Posted from Overclockers.co.uk App for Android
12 Feb 2013 at 07:33 #3 Columbo Columbo Soldato Joined 26 Mar 2007 Posts 9,073 Location Nottinghamshire For the price of a used A200, in Nikon terms you'll be looking at a D70 / D70s / D50 or Canon you'll be around the a 350D and possibly 400D mark. I'd probably take an A200 over any of those.
12 Feb 2013 at 07:50 #4 tidusjar tidusjar Soldato OP Joined 11 May 2011 Posts 2,901 Location Farnborough So the A200 is a good choice then?
12 Feb 2013 at 07:55 #5 Columbo Columbo Soldato Joined 26 Mar 2007 Posts 9,073 Location Nottinghamshire tidusjar said: So the A200 is a good choice then? Click to expand... Most certainly if you can pick one up for around £100 they are a relative bargain.
