Sony Bravia KD55X8509C Help
Permabanned
2 Feb 2010
Haywards Heath
I have the Sony Bravia KD55X8509C 2016 version
On Monday morning it was doing a software update and something happened, and we now cant get it to come out of standby mode
We have done a power reset but no luck, we do get the four android logos coming up briefly after a power reset but it wont do anything else.
Any help on this one guys
Have you tried this :-
One thing to try is to force the TV into safe mode, in case one of the applications is causing the start up issue :-
How to turn on/off the Safe mode?
https://www.sony.co.uk/electronics/...cd-tvs-android-/kd-55x8509c/articles/00127645
If not try this.
How to reset the TV to its original factory settings
https://www.sony.co.uk/electronics/support/articles/00032661
If not try this.
There is also another trick that will require a usb stick with the latest update file for the tv unzipped to a fat32 formated usb. This will try to do a forced update.
An error occurs while trying to download new software resulting in a continuous upgrade loop
https://www.sony.co.uk/electronics/...cd-tvs-android-/kd-55x8509c/articles/00121423
Remeber to format the USB stick to FAT32 and make sure nothing else is plugged into the tv that is USB only the recovery stick with the latest android update for the TV.
  • If this doesn't work, try downloading the software from the Internet (unzip the file to an empty USB key). A "*.PKG" file should be visible in the root of the USB key
  • Insert the USB key in the highest USB slot (for example USB 3)
  • If that fails, try again using another USB key and a new downloaded version of the software
Latest firmware update for your tv is here :-
https://www.sony.co.uk/electronics/...-x85xxc-series/kd-55x8509c/downloads/00016209
Also read this :-
TV does not power on / powers off immediately after start-up / keeps rebooting
https://www.sony.co.uk/electronics/...cd-tvs-android-/kd-55x8509c/articles/00125652
Blinking red LED at the bottom of the TV
https://www.sony.co.uk/electronics/...cd-tvs-android-/kd-55x8509c/articles/00075609
