Hi all, just acquired a brand spanking new W810i to replace my sadly RIP'd K750i, built it up in a custom housing so it looks awesome. This only cost me £40 so i'm looking to spec it up slightly. I'm getting a dual sim adaptor from hong kong, and i want to swap out my 4gb sandisk memory stick pro duo ultra for something larger. I was thinking 8gb... but i see there are 16gb sticks.. I'd use it eventually.. bit of a music hound (and omfg is the mp3 player good on w810is).. hurm on looking they do 32gb cards too but even i think that would be a bit excessive - could use it for portable data storage
if it wasn't £145..
They told me the maximum memory my k750i would take was 2gb.. i fitted a 4gb & it worked fine.. what's the actual max memory of the W810i? anyone tried a 8 or 16gb card in one? cheers folks
EDIT: i seem to remember the memory remaining display in phone status never read right on the 4gb card in my k750i.. saw it as some ridiculous size but i had no problem using the whole card for my mp3s... significant?
if it wasn't £145..They told me the maximum memory my k750i would take was 2gb.. i fitted a 4gb & it worked fine.. what's the actual max memory of the W810i? anyone tried a 8 or 16gb card in one? cheers folks
