Anyone else been following the Sony HMZ-T1?
Specs:
Early heads on and previews:
TweakTown: Hands On With Sony's HMZ-T1 Personal 3D Viewer
CNET: Hands-on: Sony HMZ-T1 head-mounted 3D OLED display
TomsGuide: Sony's HMZ-T1 Specs Go Stateside in November
GamingUnion: Sony Give HMZ-T1 3D Visor US Release, Price
ZDNet: Sony hopes the next TV you buy you'll wear around your head
geek.pikimal: Sony Continues to Peddle Virtual Headcrab
It may well end up being no more than a gimmick but ill be preordering one as soon as its available this side of the pond.
What are your thoughts?
Sony are preparing to release the HMZ-T1 Personal 3D Viewer, a wearable display that promises an immersive 2D and 3D viewing experience.
The HMZ-T1 is equipped with two 0.7-inch (diagonal) Ultra-Small High Definition Color OLED Panels. Sony says that the device can deliver a 720p (1280 x 720) HD image. For the 3D portion of your viewing program, the Personal 3D Viewer displays an independent HD picture to each eye, promising a more natural 3D image and no crosstalk.
Of course, the device doesn't deliver that image all on its own. It needs to be tethered to a processor, which can connect to just about all of your favorite HDMI-enabled devices. This is a Sony product, so naturally, the company wants you to pair the product with Blu-ray (2D and 3D) and gaming applications. Once everything is hooked up, all you need to do is slip the HMZ-T1 device right onto your head and slide the integrated earphone pads over your ears.
Sony says that the viewing experience is similar to watching a 150-inch screen from 12 feet away (or a 750-inch virtual screen, virtual viewing distance approximately 65-feet away). It also has virtual surround signal processing technology built in, to deliver audio that should be the acoustical equivalent of a 5.1-channel surround-sound system out of the integrated headphones.
Sony plans to start selling the HMZ-T1 Personal 3D Viewer in November, just in time to stuff a few stockings. Expect the device to be priced around $799.
Specs:
Display Technology: OLED
Display Resolution: 1280 x 720 (per eye)
Refresh Rate: 0.01 ms
Horizontal FOV: 45°
Diagonal FOV: 51.6°
Video Input: Proprietary (Video + Audio + Power)
Video Modes: Standard / Cinema / Dynamic / Custom
Video Adjustments: IPD
Video Input: HDMI 1.4a Compliant
Video Passthrough: HDMI 1.4a Compliant
Video Output: Proprietary (Video + Audio + Power)
Cable Length: 3.5m
Headphone Type: (2) Foam Covered Audio Drivers
Mass: 420g
Dimensions: 210mm × 126mm × 257mm (including headband)
Estimated Street Price: ~$799 (USD)
Availability: 2011-11
