Sony laptop help
30 Dec 2007
Oxonfordshire
Hi every one got a old sony laptop nothing great! but i use it for work.
For some reson it keeps crashing going blank and blue screen comes up.
I have a short video of this happening any clue what would be the best way to up load this.:confused:
yup nvidia. how much would it cost to replace?
NVIDIA GeForce Go 6400 with TurboCache supporting 128MB
It's intergrated on the motherboard, replacement board or you can resolder the chip buy getting it reflowed, quite a few places will do that, its the cheaper option but doesnt guarantee a permanent fix.
Would you no of any other motherboards from sony that might fit?
After having a look on fleabay nothing on there for mine just other sony ones.
