- 7 Feb 2004
Has any had any of these before? I heard that they have replaced the wire which is more stable now.
bloodline76 said:Well in a certain onilne shop there are loads of complaints about the wire stripping away, so just wondering.
ichabod crane said:ive got some of these never had any trouble with the cable so im not sure what ya mean?? there pretty good... the creative EP 630's are cheaper and perform just as well to be honest
Yep the Senns/Creatives/Sharp MD-33s are the same drivers, only difference I know (apart from maybe the wire/driver quality) is that the Sharps have a neck chain and the Creatives have a Y neck. not sure about the sennheisers though.ichabod crane said:ah k well i have not had a problem but if there fixing it then i recommend them, or the creatives or as u said in another thread the senheisers which are the same as the creatives
xb8browney said:The wire drops to peaces
bloodline76 said:Has any had any of these before? I heard that they have replaced the wire which is more stable now.
bloodline76 said:Apparently they have redesigned the wire and wondering what they are like?
