***** Sony NEX Digital Cameras now available at OcUK *****
Syd
Syd
10 Aug 2010
Sony NEX-3 with E 16mm F2.8 lens. Black (NEX3AB.CEH) @ £434.95 inc VAT
Exquisite pictures with a sense of style
Capture stunning images with DSLR-like picture quality, plus the convenience of interchangeable lenses – all without the size and weight of a DSLR. Compact, beautifully styled and brilliantly easy to use, with amazing features like 3D Sweep Panorama and HD video shooting.
Extraordinary picture quality
It's all in the sensor. The extra-large Exmor™ APS HD CMOS sensor guarantees phenomenal imaging performance - just like a DSLR camera, but without the size and weight. You'll really see the difference with richly detailed, low-noise pictures, even in low light.
Amazing HD movies
Capture smoothly detailed HD videos with quick autofocus to track the action - even while you're zooming. Beautiful background defocus effects add an extra dimension to creative movie shooting.
Small enough to take everywhere
Enjoy DSLR picture quality and super-quick shooting responses in a light, ultra-compact camera. The sensationally styled body fits easily into a coat pocket or bag for day trips, weekends away or holidays.
Pick the perfect lens
Why compromise your artistic vision? Select from a choice of compact, beautifully styled E-mount lenses - from ultra-slim wide angle to powerful telephoto zoom. Or add an optional mount adaptor and enjoy the limitless possibilities of your A-mount lens collection.
Beautifully easy to use
Don't be intimidated by complicated buttons and menus. The camera is simplicity itself to operate, with an intuitive on-screen interface, control dial and soft keys. It's brilliantly easy to make one-handed adjustments of camera settings.
- Slim, light, compact design - DSLR picture quality without the size and weight: small enough to carry with you everywhere
- 14.2 megapixels Exmor™ APS HD CMOS sensor - Large (APS-C size) image sensor captures very high resolution, low noise images with the quality of a DSLR camera: also supports HD video shooting
- E-mount interchangeable lens system - Choose the perfect lens to suit shooting conditions, just like a DSLR. Optional converter for A-mount DSLR lenses
- 720p HD movie - One-touch movie record captures crisp, detail-packed HD video clips and stereo sound for easy storage and sharing
- Sweep Panorama with 3D - Capture extra-wide images and view in 3D on compatible TV (3D requires firmware update July 2010).
- High speed burst shooting - Capture fast-moving action with rapid burst shooting up to 7 frames per second (fixed AF)
- 7.5cm/3" tilt-angle TruBlack LCD - Photo-quality (921k dot) screen with TruBlack technology for bright, extremely high contrast image preview
- Intuitive user interface - Simple control adjustments with jog dial and soft keys, plus on-screen user guide and shooting tips
- Intelligent AUTO - Automatically recognizes common shooting situations, and adjusts camera settings for beautiful results
- Background Defocus Control - Just turn the jog dial to adjust depth of focus and see beautiful blur effects previewed on screen
Only £434.95 inc VAT.
ORDER NOW
Sony NEX-5 with E 16mm F2.8 lens. Black (NEX5AB.CEH) @ £546.36 inc VAT
Capture stunning images with DSLR-like picture quality, plus the convenience of interchangeable lenses – all without the size and weight of a DSLR. Compact, beautifully styled and brilliantly easy to use, with amazing features like 3D Sweep Panorama and 1080i HD video shooting.
Amazing HD movies
Capture smoothly detailed Full HD videos with quick autofocus to track the action - even while you're zooming. Beautiful background defocus effects add an extra dimension to creative movie shooting.
- 1080i HD movie - One-touch movie record captures crisp, detail-packed AVCHD video clips and stereo sound for enjoying on connected BRAVIA® TV
Only £546.36 inc VAT.
ORDER NOW
The Nex-5 is a very good camera and this new feature of the lens design is amazing, This product is great for both novice and intermediate users.
I saw this and had a play around in a camera store the other day and really liked the look of it. I'm pretty much a novice when it comes to cameras but that piece of kit definately made me want to know more about them and possibly buy one.
IMO they look ugly as sin.
But there is probably a mthod to their madness and more than likely make up for it in quality ;)
At this price (not OcUK's fault) you're better off buying a Nikon D3000 or Nikon D3100. It's a great starter kit and you get much better quality lenses and infinitely better flashes.
A second hand D5000 would also be a perfect starter kit for somebody wanting better photos.
I can understand where most of you guys are coming from but the thing that is most attractive is that its a lot smaller and slimmer yet can offer near to or almost SLR quality (well thats what the guy said anyways). I pretty much come from a point and shoot camera bought very cheaply which does its job but if I were to go on holiday and stuff I'd like it to be handy and not so bulky looking.
