Sony PMC-D40L Help :(
8 Jul 2006
Hiya
Recently found a "SONY PMC-D40L" Stereo downstairs that no one was using. Anyways, I thought I would use the speakers for my TV until i purchase surround sound.
I have no idea how to connect it, or if it will connect. The left speaker contains L/R wires, power and a connectiom to the right speaker. So i plugged the L/R wires into my TV, no luck. I thought maybe I need the headunit so went and got it and i found out on the back it has L/R wires too, so i cant connect it to the headunit + tv at same time so I think it may not be doable?
here are some specs if it helps
Function Mega Bass Sound (Rock/Pop/Jazz/Vocal)
Modality of reproduction: Continue/Repeat/Shuffle/Program
CD Dubbing Deck to single cassette
Full Logic Insertion cassette from the high
Auto reverse Timer ignition (ST/CD/TC)
Timer Rec Sleep Timer
Best price at welectronics.com
CD Digital optical Out (MD optional)
Pre Out (diffusing) In/Audio Out (Jack Minimums): 1/1 Escape caps Jack Minimums (16-64 Ohm) Dimensions (LxAxP):
137 x 202 x 212 millimetre
Weight: 1,8 Kg
Remote control in equipment Diffusing diffusers in equipment System
active Power (Musical): 2 x 15 W diffusing Pre In Dimensions sx (LxAxP): 137 x 202 x 212 millimetre diffusing Weight sx: 3 diffusing Kg Dimensions dx (LxAxP): 137 x 202 x 180 millimetre diffusing Weight dx: 1,5 Kg
Ta!
