If you need longer than that, then you will need to splice in some extra wire, and either solder or crimp connector the cables (* disclaimer - this isn't an Audiophile solution, but honestly shouldn't make a great deal of difference, in an otherwise impossible situation).
Connectors look different. Can't see any cables with those type of connectors, just the ones linked above.
I think you may have to splice in a length of cable, if there are connectors on both ends, or just add a length if they are bare at one end.
It annoys me where I see companies like Sony doing this; one type of connector on one product and another type on a different product. It's just speaker cable FFS! Just use one type of connector.
Cut the cable and solder an extension piece in there. I'd only do one wire at a time (or very clearly label which is which) to keep the correct polarity of the speaker.
