Sony SRS X99 Replacement Advice
5 May 2022
Haywards Heath
After 5 years my Sony SRS X99 has given up the ghost and to get repaired is going to cost me £250 so i was really gutted to hear the cost , ive had since 2015
So i need advice as i am looking for another bluetooth speaker replacement ...
My budget is £300
Thanks
I am looking at the following below
Sonos Era 100
Mashall Zound Action III
Sony SRS-RA 5000
Audio Pro Addon C3
Audio Pro C10 Addon MKII
Good afternoon,
I am trying to get my Sony SRS X99 fixed, as one of the medium drivers has split, but I can't seem to find anyone anywhere to do it, not even Sony.
I was given details of suppliers who may have the part's, but they haven't replied in days, would you be able to recommend anyone please?
As for your options, I would probably stick with the Sony, they're generally very good and I would only change if I was getting a Naim Mu So, or maybe KEF, but it also depends which one you like.
Thank you for your time and help.
Kind regards
