Sony Vaio AR31e problem
13 Jan 2010
The 'Shire'
I regret ever buying anything from Sony but hey ho, I installed an SSD into my laptop without realising the silly thing never came with re-install discs the old harddrive is storage space and formatted so I cannot clone it but I thought just update it to windows 7 and everything will be fine only the Nvidia drivers only work with Vista!?!?! is there a way round this other than getting Vista again?
I phoned Sony and they want £80 to look at it and then they will charge for a service to put it back to its old state!
I also phoned microsoft to try and get a copy of Vista and they have told me my license code cannot be used on a new harddrive so want to charge £160 for a new one!
I only wanted to update this heap for CM & browsing.
Any help or if you just want to laugh thanks either way.
I have a key for both but I obviously cannot use win 7 due to Sony basically locking my laptop to Vista.
Thanks for ze help.
No those drivers from Nvidia tell me they don't work, I have tried them before I am just going to have to go back to vista I think.
The Sony driver for NVidia cards is a right pain in the ****, I have a Sony VPCCW1S1E and that uses the gt230M Nvidia card but standard NVidia drivers don't recognise it so I have to hack the latest driver and add an extra .inf file into the expanded driver, then run the setup again and it is then recognised.
I can supply you with the hacked nvszcn.inf file that allows you to use the latest Nvidia drivers. I have managed to get Windows 8.1 on my 4 year old Sony laptop and it is working superbly. This also works for Windows 7 as well.
I will give that a go, thanks
email me to my trust email address and I will forward you the file.
Just copy the file into the Nvidia folder, I use the latest 314.22 driver, just go into your C drive - Nvidia -display driver - 314.22 - Win8_WinVista_Win8 - International - display.driver folder. Then paste the nvszcn.inf into that folder, it should overwrite the file already in there. Then just run the installer again and it should then recognise the graphics card and eventually install the driver.
Rob
Go to laptopvideo2go.com it has drivers as zip files with custom inf files with the sony cars included (inf files basically say the supported laptops) you simply download the zip file extract it then download the inf file and out it in the correct folder and install. I have used this for my last two sony laptops and it works pretty well only problem I've ever had was recently one of the new drivers gave me blue screens but I tried another driver and it was fine.
Well I never tried that as I took it to PCworld(I know I know) as I thought they might just be able to sort it and give me less hassle, 6 weeks later they couldn't fix it so just installed windows 8 (without my knowledge or permission)which didn't work well with the 6-7 yr old laptop and then tried to charge me!!!
I am now going to try Wildman 33's suggestion and see if that solves it.
Thanks for all your help chaps
Merry Xmas
Got so hacked off with my laptop that I have bought Windows 7 Professional and now still have to sort the ini. file out somehow.
Couldn't get to grips with laptopvideo2go.com but will not give up on this machine.....
