Sony Vaio - two failed HDs
15 Nov 2008
Aberdeen
My brother gave me his PG7Y1M to fix when Windows failed to boot. It turns out that the boot partition was corrupted somehow. The exact same thing happened last year and the hard drive was replaced. It seems like a weird coincidence that they'd both fail, so now I'm wondering why, and whether it'd be better for them to get a new laptop or to replace the hard drive again.
I've tried to install Ubuntu to see what happens a couple of times, but each time the installation has failed. The first time it seemed to complete successfully, yet upon restart, I got a "kernel unable to load" error. The second time it just crashed 3/4 the way through.
Another thing I should mention is that their 5yr old kid uses the computer sometimes and always turns it off with the power button, rather than shutting it down - if that happened often enough, could it be the cause of the hard drive failures?
I'm tempted to recommend they go for a new laptop (I managed to get most of their files onto an external HD using the Ubuntu live disc), but the money is an issue.
Thanks.
Are you certain the hard drives were actually faulty? There are of course a few ways to check, manufacturers testing tools booted from DOS (the UBCD is good for this) are a good start. SMART tools are another like Hard Drive Sentinel.
It could easily be something else corrupting the boot partition.
what does the power button actually do?
is it set to put the laptop into standby? hibernation? or just flat out powers down
on my step sons laptop i had his set to enter standby if the button is pressed and its still working some 4 or so years later
The SMART checker on the Ubuntu live disc reports bad sectors.
arknor: It switches off the computer altogether.
Sony use Hitachi drives for some reason. It's entirely possible that you've got two Vaios with dead hard drives, they seem to be the least reliable component used in their assembly. Replace with a western digital and all will be well.
