Sony Vegas Rendering
9 Oct 2006
Location Location!
Hi!
I've been fiddling around with Sony Vegas 7 latly making little videos.
I've got a problem with rendering however to do with the audio compression.
Namly it doesn't work. I downloaded LAME mp3 encoder and installed it. Tried compressing with it and it just crashed vegas.
Question: What would you suggest to compress audio and what codecs to use as i've been stuck for an hour now trying to make this thing work?
Edit: Forgot to mention that Uncompressed audio works fine but its not exactly hdd healthy.
As far as I remember you can't compress with lame mp3 in vegas. I haven't used it since version 4.0. but when I used vegas I rendered with wmv for video and audio. You could just render both the video and the audio uncompressed and then run a 2pass xvid encoding with lame in virtualdub.
Ok, thanks for the reply.
I managed to get WMV working fine.
Was a little confused as I had mp3 encoding option before I formatted my pc :confused:
Have used VirtualDub before so I will give it a shot :)
