Hi everyone, So Im way waaay out of the loop when it comes to modern TVs Unfortunately so I’m looking for some help and advice and I just read about this online with Sony releasing their “ready for ps5” range x90h/xh90 series.
So here’s the stupid question. My 52hx903 which is approx 7-8yr old and has been an outstanding tv for me so I’m not going to upgrade just yet. I know I know the answer but it will work with the ps5 right? I mean why wouldn’t it? I know its not 4K or hdr etc but I can play the ps5 on it surely. Albeit at only 1080p
Also if I was to upgrade to this new range that Sony are pushing would this be the minimum to look for? Here some specs for their new range.
HDMI 2.1, Supports 4K/120 FPS, And I loved this bit as not many manufacturers usually give this info. Low input lag 7.2ms.
Now this seems brilliant with just this small bit of info but what about support for hdr. Do all decent TVs have this now?
I don’t really care what smart features they have as I use my PS4 for all my needs and soon the ps5 but I believe the android smart system they use is good.
What else should I look out for if I would like to have it “future proof” as I do tend to get attached and keep things for quite a while so I want to make the right choice.
Mid range is fine and I would like to say around £1000 would be my limit but a bit extra for something more superior would be ok.
I’m not really into the whole oled thing as I believe they suffer with screen burn and their probably out of my price range anyway.
I do like Sony TVs which is the reason the article caught my eye but I’m open to suggestions.
Any help advice much appreciated
