Be careful with poly engine mounts, they can cause problems.
Firsty you'll most likely have increased vibrations through the car at idle. The virbrations that the flex in the original mounts would usually deal with will be transferred elsewhere.
Secondly, if not all the mounts are being done then the ones that aren't will wear quicker due to do the fact any movement that used to be spread over all of them will probably be transferred to these. As the poly ones will not really flex the movemnt has to go somewhere. If you are doing all the mounts then be careful as it can do nasty thigns to where the mounts bolt into.
I put a strengthened lower mount on my Clio, it lasted 2 days before I took it off. Vibrated more at idle and when giving it some where the engine used to be able to move a bit it now couldn't and the movement was transferred to the exhaust manifold causing it to hit the subframe and rattle.
Others who have had them on for longer have also had a shock when the thread the mount bolts onto breaks, as the mount itself can't flex the force was transferred to the thread itself. I'm now going to chuck a genuione new mount on when I can be bothered as the one thing the new mount did do was firm up the gear change a lot.
Saying that, this is just my experiances, other cars may react differently, but in principle it can stil cause problems
