Sorry. Another problem.
20 Nov 2010
Sorry to have so many problems lately.
When I start up my computer the black screen comes up with the computer's information. It displays: 2.3 GHZ.
Now, when the computer is up in Windows and I go to Control Panel, System - it only shows it having 1.2 GHZ.
I do have a CPU disc, but I don't want to risk doing anything with that when I'm not sure.
Also, my RAM isn't working. One slot does and the other doesn't. I've had to take that out to even get my computer working as the screen remains black if I don't. Going to need to get new RAM but not sure what will be compatible with my comp.
Many thanks in advance. :)
speed step or cool n quiet is enabled, this will reduce the speed to save power while the cpu is doing sod all.
I think cool and quiet is disabled but I will check in BIOS again.
Operating System
MS Windows XP Professional 32-bit SP3
CPU
AMD Phenom X4 9650 27 °C
Agena 65nm Technology
RAM
2.0GB Single-Channel DDR2 @ 267MHz (4-4-4-12)
Motherboard
ASRock N68-S (CPUSocket) 31 °C
Graphics
W2243 @ 1920x1080
NVIDIA GeForce GTX 460
Hard Drives
977GB MDT MD10 EACS-00ZJB0 SCSI Disk Device (Unknown) 36 °C
Optical Drives
Optiarc DVD RW AD-7200A
Audio
Unimodem Half-Duplex Audio Device
As for the RAM, do you think it has had it?
When I put both RAM in the screen won't show, just remains black but it is only doing it with the one card. Need to buy more RAM, but not sure what is compatible?.
Will my computer accept higher RAM like DDR3 even though it currently has one slot of DDR2 as I had to remove the other one. I did have 4GB RAM but now only two.
Thanks. :)
one way of checking the cpu speed is to downlaod CPU-Z, it will clearly show the core frequency.
If it looks too low, then run a simple stressful program such as super-pi/prime 95 side by side the open CPU-Z program and watch to see if the core speed rises?
i'M USING sPECCY.
dETAILED cpu INFO@:
CPU
AMD Phenom X4 9650
Cores 4
Threads 4
Name AMD Phenom X4 9650
Code Name Agena
Package Socket AM2+ (940)
Technology 65nm
Specification AMD Phenom(tm) 9650 Quad-Core Processor
Family F
Extended Family 10
Model 2
Extended Model 2
Stepping 3
Revision DR-B3
Instructions MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Bus Speed 200.9 MHz
Rated Bus Speed 1004.6 MHz
Stock Core Speed 2300 MHz
Stock Bus Speed 200 MHz
Average Temperature 28 °C
Caches
L1 Data Cache Size 4 x 64 KBytes
L1 Instructions Cache Size 4 x 64 KBytes
L2 Unified Cache Size 4 x 512 KBytes
L3 Unified Cache Size 2048 KBytes
Core 0
Core Speed 2310.7 MHz
Multiplier x 11.5
Bus Speed 200.9 MHz
Temperature 28 °C
Thread 1
APIC ID 0
Core 1
Core Speed 1155.3 MHz
Multiplier x 5.75
Bus Speed 200.9 MHz
Temperature 28 °C
Thread 1
APIC ID 1
Core 2
Multiplier x 5.75
Bus Speed 200.9 MHz
Temperature 28 °C
Thread 1
APIC ID 2
Core 3
Multiplier x 5.75
Bus Speed 200.9 MHz
Temperature 28 °C
Thread 1
APIC ID 3
