Wanting to build a new gaming rig, my starting spec is as per image:
Plan is to use for gaming mostly, with the addition of an HD-DVD drive in due course. I'll be using an exiting DVD RW in the meantime.
I'll be running everyhting at std spec at the outset but may look into OC'ing later. Assuming addirional cooling is added, is the spec above OK to OC'ing?
A couple of Q's though:
1. Will the board handle SLI, if needed at a later date? On the Asus website, it confirms Crossfire, but not specific about SLI. Also, will the 520W be enought to cope with a 2nd 8800GTX, for example?
2. I'm hoping to use the two HDD's in a RAID 0 config. Is it possible to add a later HDD and have a selectable bootable OS on it (i.e. to choose whether to boot using XP or Vista)?
Would really welcome any comments/change suggestions.
Ta.
Ta.
