Sorry, but im going to get one of these....
6 Feb 2004
Wiltshire
136 views and no opinions, cats got your tongue ?
or what about the;
2003 Univega RAM 970 frame with RockShox Duke SL Air fork with 100mm travel, compared to what i have already?
http://www.chainreactioncycles.com/Models.aspx?ModelID=6073
I would obviously take the decals off as they are pretty bad. Any opinions on what i should do, always nice having some opinions before i spend £300 - £350
Thanks
I'm guessing that's because your title is vague and people don't know what it is about untill they view.
I don't have any real advice apart from the univega frame isn'y as good as the BeOne even though they are both tiawanese catalogue bikes.
P.S. If you asked for advice about what frame to buy for a certain budget and certain purpose, I think you will get a better response.
