Sorry for another monitor thread
8 Apr 2014
Lincolnshire, UK
Budget is at £500 but i don't necessarily have to spend every penny.
Currently have a 980Ti and a 24" led backlit 1080p benq monitor which has been great so far.
I don't play any online FPS games. I usually play mostly arcade, adventure or RPG games so the picture quality is important but response time doesn't have to be ridiculous.
I sit about about half a metre away from the screen currently so i don't really want anything massive, was looking at the 27/28" mark.
im not sure whether to go for a 1440p, or 4k monitor, i found the ACER Predator XB281HKBMIPRZ which seems to tick all the right boxes on paper... just wondering if anyone has any alternatives or has exprience with this particular one and can vouch for it!
thanks in advance!
Bit of a waste to go 4k on 28". 4k shines on larger screens. On 28" you will be hard pressed to notice any difference between that and 1440p at half meter away. If 1440p, 27" is the standard and should be plenty decent ones to choose from at £500 or below.
