Sorry for ANOTHER thread... Extending Network Airport Express
18 Oct 2002
So, this should be simple in my mind.
Out house clearly has triple lead lined walls, so as well as making use of it as an airplay station, we are going to use the Airport Express as a network extender in the kitchen.
My genius (?) plan is to homeplug from the time capsule into the airport express so it has a wired connection to the time capsule.
Homeplugs are plugged in and chatting along nicely, but how on earth do I configure the airport express to connect to the network through wired, and then extend the existing network?
Is it as simple as 'extend network' and it knows it has a path back through the wired connection somehow?
edit - ignore me.
If you ever want to do this. Reset your Airport Express to factory settings, plug everything in, select connect to an existing network, and a new wizard will load. When doing this, you will find the answers in the wizard !
Sorry !!
