sorry, spec check please?
Permabanned
19 Nov 2002
sorry, hope you dont mind too much, does this look ok to you guys? most concerned with memory/motherboard combo.
thanks
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£214.95 £214.95
Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO)
£179.95 £179.95
G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS)
£106.95 £106.95
Seasonic S12 600W Silent ATX2.0 Power Supply (CA-002-SS)
£83.95 £83.95
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
£87.95 £87.95
Subtotal £673.75
VAT £117.91
Total £791.66
Yes that Gskill RAM will not work in your board, you might wanna try the Corsair 2GB DDR2 XMS2-5400 TwinX :)
Other than that looks good to me mate
Stelly
cheers stelly, what about Corsair 2GB DDR2 XMS2-6400C5 for £15 more than the one you suggested? still ok? or is it the c5 stuff thats flakey?
Nope that should work fine, I think that you should go for the 6400 mate :)
Stelly
