Sorry to ruin your weekend! - CS:GO Freeze/Sound loop problem.
9 Dec 2014
Gloucestershire
Good evening guys, I bring to you a problem!
For the past few weeks, my Counterstrike has been freezing/sound looping during Competitive matches and is forcing me to have to turn my computer off from the tower itself as it will not respond.
I've googled the problem a few times and tried the common answers*
*Verify Game Cache
*Clean Install
*Disablemotd
*Updating to the latest GPU drivers.
*Reduced settings in-game.
I haven't had problems with any other game including the likes of GTA / higher end games, so i'm pretty sure it isn't a faulty piece of hardware.
Windows 10.
AMD FX - 6300 Processor
AMD Radeon R9 285
Gigabyte GA-970A-UD3P MB
8GB Crucial Ballistix RAM
500W EVGA 80+
Thanks for reading (and hopefully helping!) :)
Does it do it at a certain point every time? Sometimes transitioning to and from menus I get a sound loop momentarily.
Have you checked the windows logs? Usually a freeze can spit out a MiniDump file. I can take a look at it for you if you like. Could be a driver issue or overclocking issue only CS is exposing.
I had a mega freezing issue that knocking 5Mhz off my FSB fixed (I am running old Q9550 though, has been clocked for that long haha).
It doesn't seem to be time-specific, it just happens randomly at any point during the round.
I haven't checked any Windows logs, wherever they lie!
Right click Start > Computer Management > Event Viewer > Windows > System
Looks for error and critical, if nothing, go up a level and check application logs.
Disable multi-core rendering, render in window mode (so you can monitor more easily, and possibly won't have to reboot), check audio drivers, run an exhaustive memtest86 overnight, run a cpu stress test (could be overclocking / CPU settings issue), monitor your real time GPU and CPU temps (if it's overheating, could be a unseated HSF)... It's a pain, I know, and I've been there.
Even if it works in other games, I would't discount a hardware fault / BIOS setting. Running less technical game means it's gonna run at a much higher frame rate anyway. Although technically, GTA5 IS a stress test :)
Could also be something software related, I'm looking at you, Cortana / IE (there is an in-game browser in CS, yes?).
Does this help? I'm going to have a guess and say its something to do with the Kernel-Power thing? I played two games yesterday (unsure on exact times) but both resulted in the computer freezing and having to be reset
Going to run some of these tests now. Thanks for the reply.
Ran CCleanner, deleted all the registry options and unwanted files, opened up the case and gave it a clean. Also limited FPS in CS:GO.
Managed to play two games and had zero problems in regards to stutters or freezing, so hopefully that will be that.
Thread can be closed/deleted.
Thanks! :)
