Sound bar with built in Alexa?
6 Jan 2006
Newcastle upon Tyne
Can anyone recommend a sound bar that has a built in Alexa? It’s for the spare room so won’t get huge amounts of use so looking at somewhere in the £150-200 region if possible.
Thanks.
There are not a lot of cheap options out there with Alexa you could up your budget a bit and get something like the Polk React which has reviewed pretty well and could grow into a system. Otherwise you are into Sonos, Bose and Sony money which blows your budget completely.
Hmmm I may have to rethink things. I was hoping for an all in one solution but I have an echo dot I could use which I could possibly Bluetooth to the soundbar.
Another quick question, what are sound bars like without a sub? I’ve had a couple with a sub and you can really tell there is extra bass there. Appreciate at £150-200 level that I’ve had/got it’s probably crap bass but you will get a bit of a rumble on films etc
