it will still sound better than budget onboard audio, might need new capacitors though.unless you have an antique pc without sound your probably better to just bin it.
this. save yourself the hassleunless you have an antique pc without sound your probably better to just bin it.
unless he is an audiophile, I don't he would be able to tell, and if he really was then he would buy a new one, solving all problems while sounding the best it could!it will still sound better than budget onboard audio, might need new capacitors though.
will it though?it will still sound better than budget onboard audio, might need new capacitors though.
i do, i have a 2.0 studio speakers. and most good monitors dont have sound built inWho in this day even uses the on-board soundcard on a motherboard?
what is the DP delivering sound to? because the monitor you have in the sig(LG Ultra Gear 32GN600-B 165Hz 1440P) doesn't have sound built inI disable mine and just let DP deliver the sound via the GPU?
The important part is the DAC, the monitor one is probably inferior to the onboard, wouldn't hurt to try it and see if you can hear a difference.What would be the advantage
Of using displayport for sound compared to
Onboard audio?
Most monitors have either no speakers
Or pretty poor speakers
I guess I could use display port then plug my speakers
Into the monitor 3.5 jack
But does a gpu process sound better than onboard sound chip
Is probably what I am asking
Should say got a top end motherboard
And the sound part of it should be pretty good
Which is probably why I never tried this
Motherboard apparently is SABRE9018Q2C integrated DAC amplifierThe important part is the DAC, the monitor one is probably inferior to the onboard, wouldn't hurt to try it and see if you can hear a difference.
No idea about monitor dac
Seems like an ESS DAC so the board's audio is probably better than the monitor's.Motherboard apparently is SABRE9018Q2C integrated DAC amplifier
No idea about dacs to be honest
But its a premium motherboard so would expect that
to be decent
Just tried audio through monitor
But speakers are so much quieter it's hard to compare
Guess I will have to fumble around trying to find the 3.5 jack
They never seem to put them in easy to reach places
Now this has got me wondering
The monitor can do dp alt through usb c
Can that be used for a usb dac?
Got a rog clavis somewhere
Must admit all this isn't stuff I am that familiar with
Yeah wasn't even a close competitionSeems like an ESS DAC so the board's audio is probably better than the monitor's.
Tested with November rain
As its got vocals,orchestra instruments, electric guitar solo etc
Plus I happen to like guns and roses lol
