Sound Blaster command software
Commissario
18 Oct 2002
Down under mate!
Hi gents,
I have a new rig incoming, and decided to go with Z SE Performance card.
Does the software allow you to flick between the rear and front audio ports?
Any issues using this with Discord, teamspeak etc?
Not sure I'm reading this right but front audio port as in the one built in to your PC chassis?
I have a Zx
I have many problems with audio shifting channels and also a nasty clicking every now and then when using SP/Dif. If I switch modes it fixes it for a time. I would not recommend this series of cards with modern Windows 10 or 11.
When I used to have headphones and speakers plugged into my Z you could toggle between them in the old version of SB command (pre Z SE) and it worked fine with TS/Discord/game. I’ve not tried the new SB command fwiw.
