Sound card for Antec 900 Case
27 Aug 2007
Whitley Bay
Hi,
Just put my new system in an Antec 900 case. There is a connector for the front mic/speaker which has two connectors on the end. one for HD Audio the other AC97. The HD fits to my onboard sound but the quality is poor (especially on recording - ASROCK Dual VSTA mobo).
So I thought I'd drop in the card from my Sound Blaster Live setup and just not use the 5 1/4" beige drive bay. However there doesn't seem to be any connector that will fit the cable/s in the Antec. Each of the connector has one of the 10 pins blocked out.
So, is anyone familiar with this card? Is there a way to connect my Antec cables to it? Can anyone recommend a cheap'ish alternative that will connect and will work with Linux.
Needless to say I don't have the manual or anything to check connections!
Any help much appreciated
Cheers
Andy
