Sound card & front panel Audio?
17 Jul 2006
HI couple quick questions
Putting together first system :o and have run into stumbling block with front panel audio connections + where the hell they go. I've put in the USB connections + power/reset LED's etc but there's ******* loads of tiny 1 pin jobbies for the sound.
Bearing in mind i'm putting in a soundcard (emu 0404) which will be hooked into home stereo, i'd gladly not use front panel audio at all, disable onboard sound and jam those tiny connectors into an empty drive bay.
Will this work?
Oh yeah it's an Antec p180 + Asus P5W DH (has "Q-connector" things)
Will this work?
Best course of action IMO, everything will still work :)
