Im just a bit tired of having a really good machine with blistering graphics but really crappy audio, im using onboard sound and have Steel Series v5h2. The headset has been brilliant but i think its dying because it keeps making crackling noises and if i turn the volume really high only the left side works.
I basically Game a lot so i require a head set + sound card which will provide positional accuracy so i know where my enemies are, i also listen to music and would like the quality of that to be really good aswell.
Here is my PC spec;
Gigabyte GA-X48-DQ6 Intel X48 (Socket 775) PCI-Express DDR2 Motherboard
Corsair 4GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x2GB) Supplied with Airflow Fan (TWIN2X4096-8500C5DF) (quantity x2) So 8GB in total
Intel Core 2 Quad Q9450 LGA775 'Yorkfield' 2.66GHz 12MB-cache (1333FSB) Processor - Retail
2x Powercolor ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail in crossfire mode
Vista 64 bit Ultimate
I would just like everything to be compatible with each other, fit and work well bear in mind im using crossfire so i dont know which card will fit on that motherboard with 2 graphics cards installed. Budget is around 150 to 200 quid. Thankyou for your help guys
Here is my PC spec;
