Sound card recommendation
29 Sep 2014
East Yorkshire
Hi all
moving to guy a sound card as the next step in my build as the onboard is always a poor choice.
Last card I had was a SB Audigy about 10 years ago. Can people give me some views on what to get. Looking at £50-60 spend and it will be for games and music. I have Sennheiser Momentum headphones to use so I want to be worth it for them.
thanks in advance
Either of the two previous recommendations, or a Xonar DGX for those who don't want to spend a lot.
If you've got speakers to use as well, SB Z or the Xonar U7 are the best choices. Both have connections for headphones and speakers. Anything else for around the same budget or less, you have to use a switcher or front case audio in order to connect both.
Given your headphones, I'd probably favour the U7, mainly because the Momentum's are low impedance, whereas the SB Z is high gain output with no options for lower setting. In other words, you get stupidly loud volume from only a low percentage of the SB Z volume slider.
Thanks all. Didn't realise that external cards were so popular and interestingly from what you've all posted "better" than internal.
a quick question, why external? I'm just curious
Internal sound cards are more susceptible to interference from the graphics card, specially when two or more are use in SLI or Crossfire.
Interestingly looking at my motherboard the two pcie slots free are either side on an 970 (fan side or behind) so might get a bit hot as well.
Thanks for the help
