- 4 Dec 2009
If using digital output from either a good quality sound card or onboard, am I right in assuming that sound quality should be identical as the data has been passed out to the amp?
DDL is a real time 5.1 encoder. SPDIF is actually stereo, not 5.1. It can handle multiple channel data, but it has to be encoded, that's where Dolby Digital and DTS come in. When you watch a DVD, the Dolby or DTS encoded audio contained on the DVD is passed to the amp via SPDIF, which the amp then decodes. If someone wants to play a game for eg, the 5.1 data from the game can only be sent as stereo, it needs to be encoded with Dolby Digital or DTS. DDL does that, it takes the 5.1 data then encodes it to Dolby Digital, then is passed on to the amp.
I hope that made sense. I will try to clarify it, if I made it sound too complicated.
Certain sound cards have the DTS equivalent, DTS Connect.
