as long as your player supports pass thru over optical (most do) then yeah youll be fine, but you do know you wont get any better sound quality just by using optical. using 3.5mm jacks will result in equally good quality as it just means the dolby digital is being decoded by your sound card instead of your reciever. and if your doing anything other than watching movies, compressing everything to dd/dts via dd live or dts connect is actually degrading your quality as both formats are lossy, so id stick to analogue myself
