Sound Cards... When to bother?
8 Jan 2007
Hi guys,
My question is - in 2019, with massively improved onboard Audio... When does it start to be beneficial to use a seperate card.
Currently I'm using an SB Z PCI-E OEM model... but I have a Gigabyte Gaming Z170 motherboard (which looks like it has pretty much all the same connectors)...
Will my audio be any different? Or do we think that pre-£100, Audio cards are pointless?
I read somewhere that an SB Z is not a "real" audio card, whatever that meant.
Cheers
Examples:
Some on-board implementations are poorly implemented.
You may have higher impedance headphones which require an amplifier
You might require low-latency mixing
You might require inputs or outputs not available from an onboard implementation
Some headphones (the expensive ones) can require an amp or soundcard to drive, the onboard solutions can't provide the impedance needed.
Some people still say the soundstage is wider from a soundcard - your mileage may vary.
Some soundcards can encode Dolby formats, which may be required for certain surround sound outputs to an AVR system.
Cheers
I have a Gigabyte Z170 motherboard and have issues with the sound (it would sometimes completely distort and go to volume 100, only fixed by a complete reboot). It is what drove my interest in looking at an external solution and why i ended up getting an external USB DAC.
