Sound Cracking, High Latency
9 May 2009
Hi
I have recently purchased a pre built system (not from oc so wont list the website) i am getting sound glitches so have done some research and checked my latency, seems my wifii card is causing the problem, i have checked all the drivers and even uninstalled them and updated from the ASUS website, when i disable the driver the sound works fine.
I have another WiFii card from my last system which in fact is a better card which i am gong to try tonight when i get home but if this dont work does anyone have any ideas?
thanks in advance!
Wouldn't be first time for Wifi card to cause latency issues.
What's the card causing problems?
(Atheros?)
the card is asus pce-n15 11n, crackling is still happening, i will try my other card
saying that it isnt happening now where near as much, seems to be ok now, i will have to monitor it and try the other card if needed
I absolutely hate wifi. I spent so much money and time realising that it doesn't achieve anything like the performance it's supposed to. I would replace it with power line units or even better a simple wire.
+1 for power line adapters. I’ve always used one and never had any issues
