sound dampening foam help
well i'm having it setup (hypotetically speaking) assuming things come out which i need, but my haf i have 13 3.5" bays now to
Wish I had that kind of cash.
i9 + mobo - rad 120.2/3
2x gpus - rad 120.3
3x gpus - rad 120.4/140.3
Makes sence I guess - not your normal pc then
Edit: mountain mod case springs to mind
so you have the rads and fans but no i9 or gpu's yet???
i9 + mobo - rad
2x gpus - rad
3x gpus - rad
well, i'm componenting it up hopefully next summer (when i hopefully will have the money) it may only set out with 2-3 gt 300s though dependent on the finance but in the end it shoudl have them all
But even then i have seen setups like that with only half the fans you are using and they still run cool and stable, just try removing a few and see what happens, no offence meant mate.:)
Pre build, you might also want to look at using PA or RX rads - 3x 800rmp fans will give excelent results on these - I run my PA120.3 (cpu/NB/GPU) without any fans and my system runs OC'ed 24/7 at load - It's no gaming monster but it still shows how good the PA's are.
Intel I7 920 CPU
ASUS P6T6 WS Revolution Motherboard
6 Gig DDR3 Memory
6 12inch PCIE flexible extenders.
6 9800GX2 dual GPU Video Cards.
1 Custom WU Milking Machine Frame
Folding farm - only reason i can see for a 5 card setup
Intel I7 920 CPU
6 Gig DDR3 Memory
beautiful setup, how may pci lanes does the core i7 have?
