Hi all
I'm going to be making myself a 5.1 splitter box so I can switch between my Creative 6.1 system (upmixing from 5.1 as I'll be losing the custom centre-rear channel) and soon-to-be-purchased Roccat Kaves.
Before I go ahead with it, I'd like to check with all you sound gurus if I'll get any appreciable loss in quality, and some advice on the wire to use as it's been a LONG time since I did anything with electronics.
The switch I'll be using is rated for something like 0.5A and 10~20mΩ resistance - doesn't strike me as causing a problem, but I'm rather clueless atm.
Also, what sort of speaker wire should I use to wire my 3.5mm jacks and the switch? Obviously I don't want anything with high resistance, but we're only talking about a bunch of 4cm lengths (if that) between each jack and the switch, so is it going to matter too much? In fact, to make things tidier, could I PCB mount the whole thing and use the copper tracks instead of wires?
Or am I totally barking up the wrong tree here just because I can't find a 5.1 switch box and I don't want to keep switching the leads between speakers and headset?
Ta muchly
Ta muchly
