Sound files for older versions of MSN
27 Dec 2002
Inverness
Does anyone out there have the slightly older MSN notification sounds? I now have MSN Live but the sounds on it are nasty, would quite like the old ones back really (MSN 7.5 ish??) I have switched them off for now as they are irritating me so much but I do find them useful to have sometimes. Email is in profile if anyone could send me them.
Worst comes to worst I will just have to install the old version and then reinstall this one but it's a bit of a faff.
cheers
You could always visit olderversion.com, download an old version of MSN, go to the installation directory, copy the sound files over to the MSN Live directory, and renaming them. Should work I think, good luck with it.
If I am having a blonde moment forgive me.... I have already been to olderversion but it's just the .exe you can download. Once you try and do anything with it, it wants you to uninstall the newest version. Unless I am being a noob and missing something else I could be doing
Install the old version, copy the files you need, reinstall new version, point sound noticifcations at the old files.
Aye I already knew I could do it that way (as per first post), but thats precisely what I wanted to avoid. Anyway sorted now, thanks for looking and the help anyway everyone.
