Sound Fonts & Midi Files
6 Feb 2004
Ballymena
Hi i have downloaded some midi files of songs i like which are very close to the original apart from the terrible sounding instruments they are being played on by default, I was going to buy a new Sound Blaster Sound Card that allows you to work with Sound Fonts, Can some one give me instructions on how i can change the default instruments used in the midi file to the sound fonts which my card will support and also which software i should use to do this procedure too.
Many Thanks
