Troubleshooting!
Parts list:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor
CPU Cooler: be quiet! Shadow Rock Slim 67.8 CFM Rifle Bearing CPU Cooler
Motherboard: Gigabyte GA-Z97P-D3 ATX LGA1150 Motherboard
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Palit GeForce GTX 970 4GB JetStream Video Card
Case: Corsair SPEC-01 RED ATX Mid Tower Case
Power Supply: be quiet! 500W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Monitor: Asus VG248QE 144Hz 24.0" Monitor
Headphones: Creative Labs Creative Fatal1ty Headset
Headphones: Superlux HD681 Headphones
Problem:
When plugging any headphone into any audio port on my pc, i hear constant crackling noises and get no other sound output whatsoever.
The problem appeared first when i moved my pc to my brothers room, removed my GTX 970 and installed his new R9 270 along with the AMD Catalyst drivers.
Trying to fix it by:
After installing the Realtek drivers the crackling noises turned into beeping rustling ones that increase with the pc's volume settings.
At least the R9 270 worked fine... Is my mobo broken? Do i lack any drivers or have to enable anything? Do i need to buy a PS4 now? I'm clearly losing my mind already, please help me!
Parts list:
Problem:
- Putting my GTX 970 back in
- Plug another headphone into any audio port
- Plug both headphones into my smartphone, both work there
- Uninstall AMD Catalyst drivers normally, then with Display Driver Uninstaller
- Reinstall the current version of my Realtek audio driver
- Reinstall Nvidia Geforce drivers
- Reset BIOS through shorting the CMOS pins on my motherboard for 5 seconds
- Reinstall Windows 10
- Install Nvidia drivers again
- Install Realtek audio drivers again
