Sound Interference
2 Nov 2006
Leeds, West Yorks.
Quite a strange one, may actually be more common than I think but my headphones connected to the back of my case directly in the motherboards sound card I get no sound interference at all, however connected to the side panel on my case I get a faint buzzing/hum sound? What’s causing this? I really need to use my side panel rather than messing about behind my case every time I need to get my headphone out,
The motherboard is a Gigabyte GA-G33M-DS2R, which uses Realtek ALC889A audio.
Any info would be great :)
Tonight for the 1st time i started to get the same sort of interference , and the cause for me was i started to use one of them cable tidy's , but obviously the headphones are now getting interference from being so close to the power cable's , su just make sure that when you are using the side connections, that your headphones lead is not near any other electrical leads.
Wisdom ^
And if the interference is getting into that port from inside the machine, get a little extension lead, and run them from the "good" socket.
