Sound issue on Intel BX2
3 Jan 2007
Invisibleville
Ok, i have a sound issue on my board and it's not just the onboard sound it's also the sound coming from the card (Auzentech Meridian) too. The speakers and card work fine as they did in my old system, so i've put it down to the board, there are no wires going across it's surface or anything.
The strange thing is, the sound worked when the case was left sideways during the setting up and testing, then when i put it upright the sound went really quiet and quality was bad. It would return to normal if put sideways without fail, and then if i gently put it back upright it stays. Occasionally jolting the thing brings the sound back. It's not the cards position in the pci slot either because i've had a play with it, and doesn't seem to affect it.
I upgraded the bios in hope it would solve something but was weary, and now it is permanantly quiet whatever i do.
The posts on the board are on correctly and i have all the drivers, this is a fresh install on new hard drives.
I know there's something i've done wrong, but just can't figure it out, anyone else have this problem, i've googled it, and people seem to be getting the same sound issues. Any help or suggestions would be appreciated, thank you.
Fixed, i knew it was something stupid, after many uninstalls and installs, it was obviously a setup problem. Turns out the massive psu wires off the tagan were interfering somehow from the other side of the case, shifted them a bit and now balance is restored.
So yeah, now u know! bloody massive psu wires, wish i could unscrew them like on a silverstone, owell.
