sound like a faulty hardware?
11 May 2011
So random times i get *Display drivers AMD display driver stop responding has successfully recovered* there doesnt seem to be any pattern.
so far ive tried the following:
Re installed the graphics card(and updated to latest)
turn fan high (inc it was temp)
turn off clocking / turned it down
Re installed windows 7 and re install drivers
upgrade the power supply
does it sound sound like a faulty hardware? the annoying thing is i just bought this computer like 2 1/4 weeks ago and this been happening since i got it but due to a lot of ppl saying it might be the power supply i tried to upgrade it to a 600w gaming psu.
It will happen like 3 times in a row then go back to normal for a while its really weird. Im on the edge atm tempted to buy a new nvidia graphics card but dont really want to spend 200 pounds if it wont fix the problem.
My speccy file, is 600w ok for this system ? i know its not prime for it
Summary
Operating System
MS Windows 7 Home Premium 64-bit SP1
CPU
Intel Core i7 3770K @ 3.50GHz 41 °C
Ivy Bridge 22nm Technology
RAM
32.0 GB Dual-Channel DDR3 @ 666MHz (9-9-9-24)
Motherboard
ASUSTeK COMPUTER INC. P8Z77-V LX (LGA1155) 27 °C
Graphics
SAMSUNG (1360x768@60Hz)
AMD Radeon HD 7800 Series
Hard Drives
466GB Seagate ST500DM002-1BD142 (SATA)
Optical Drives
Optiarc DVD RW AD-5280S
Audio
Realtek High Definition Audio
Operating System
Computer type: Desktop
Installation Date: 14 July 2012, 20:56
Serial Number:
Windows Security Center
User Account Control (UAC) Enabled
Notify level 2 - Default
Windows Update
AutoUpdate Download Automatically and Install at Set Scheduled time
Schedule Frequency Every day
Schedule Time 3 am
Windows Defender
Windows Defender Disabled
Firewall
Firewall Enabled
Company Name Symantec
Display Name Norton Personal Firewall
Product Version Unknown
Antivirus
Antivirus Enabled
Display Name Norton Internet Security
Environment Variables
USERPROFILE C:\Users\Rob
SystemRoot C:\Windows
User Variables
TEMP C:\Users\Rob\AppData\Local\Temp
TMP C:\Users\Rob\AppData\Local\Temp
Machine Variables
ComSpec C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK NO
OS Windows_NT
Path C:\Program Files (x86)\AMD APP\bin\x86_64
C:\Program Files (x86)\Intel\iCLS Client\
C:\Program Files\Intel\iCLS Client\
C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\
C:\Program Files\Intel\Intel(R) Management Engine Components\DAL
C:\Program Files\Intel\Intel(R) Management Engine Components\IPT
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT
C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE AMD64
TEMP C:\Windows\TEMP
TMP C:\Windows\TEMP
USERNAME SYSTEM
windir C:\Windows
PSModulePath C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
NUMBER_OF_PROCESSORS 8
PROCESSOR_LEVEL 6
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
PROCESSOR_REVISION 3a09
windows_tracing_logfile C:\BVTBin\Tests\installpackage\csilogfile.log
windows_tracing_flags 3
AMDAPPSDKROOT C:\Program Files (x86)\AMD APP\
Power Profile
Active power scheme Home/Office Desk
Hibernation Enabled
Power Shutdown Enabled
Power Suspend Enabled
Turn Off Monitor after: (On AC Power) 20 min
Turn Off Hard Disk after: (On AC Power) Never
Suspend after: (On AC Power) Never
Screen saver Enabled
Uptime
Current Session
Current Time 14/07/2012 14:07:12
Current Uptime 14331 sec (0 d, 03 h, 58 m, 51 s)
Last Boot Time 14/07/2012 10:08:21
Last ShutDown Time 15/07/2012 00:30:37
Uptime Statistics
First Boot Time 14/07/2012 20:31:51
First Shutdown Time 14/07/2012 20:38:01
Total Uptime 27638 sec (0 d, 07 h, 40 m, 38 s)
Total Downtime 1135 sec (0 d, 00 h, 18 m, 55 s)
Longest Uptime 36752 sec (0 d, 10 h, 12 m, 32 s)
Longest Downtime 260 sec (0 d, 00 h, 04 m, 20 s)
Total Reboots 10
System Availability 96.06%
TimeZone
TimeZone GMT -8 Hours
Language English
Country United Kingdom
Currency £
Date Format dd/MM/yyyy
Time Format HH:mm:ss
Scheduler
14/07/2012 14:17; Adobe Flash Player Updater
14/07/2012 21:24; GoogleUpdateTaskMachineCore
14/07/2012 21:24; GoogleUpdateTaskMachineUA
Process List
atieclxx.exe
Process ID 1360
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\atieclxx.exe
Memory Usage 1.84 MB
Peak Memory Usage 7.21 MB
atiesrxx.exe
Process ID 1020
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\atiesrxx.exe
Memory Usage 312 KB
Peak Memory Usage 4.84 MB
audiodg.exe
Process ID 4200
ccc.exe
Process ID 2340
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CCC.exe
Memory Usage 49 MB
Peak Memory Usage 169 MB
ccsvchst.exe
Process ID 2288
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Norton PC Checkup\Engine\2.0.15.96\ccSvcHst.exe
Memory Usage 1.32 MB
Peak Memory Usage 9.55 MB
ccsvchst.exe
Process ID 2296
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Norton Internet Security\Engine\19.0.0.128\ccSvcHst.exe
Memory Usage 9.99 MB
Peak Memory Usage 29 MB
ccsvchst.exe
Process ID 1796
User SYSTEM
Domain NT AUTHORITY
Memory Usage 2.82 MB
Peak Memory Usage 9.62 MB
ccsvchst.exe
Process ID 1760
User SYSTEM
Domain NT AUTHORITY
Memory Usage 15 MB
Peak Memory Usage 102 MB
chrome.exe
Process ID 1816
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Memory Usage 97 MB
Peak Memory Usage 109 MB
chrome.exe
Process ID 5936
User Rob
Domain Rob-PC
Memory Usage 251 MB
Peak Memory Usage 280 MB
chrome.exe
Process ID 1992
User Rob
Domain Rob-PC
Memory Usage 84 MB
Peak Memory Usage 202 MB
chrome.exe
Process ID 2448
User Rob
Domain Rob-PC
Memory Usage 24 MB
Peak Memory Usage 24 MB
chrome.exe
Process ID 988
User Rob
Domain Rob-PC
Memory Usage 31 MB
Peak Memory Usage 36 MB
chrome.exe
Process ID 3352
User Rob
Domain Rob-PC
Memory Usage 31 MB
Peak Memory Usage 31 MB
chrome.exe
Process ID 4680
User Rob
Domain Rob-PC
Memory Usage 9.42 MB
Peak Memory Usage 9.42 MB
chrome.exe
Process ID 4700
User Rob
Domain Rob-PC
Memory Usage 34 MB
Peak Memory Usage 34 MB
chrome.exe
Process ID 4312
User Rob
Domain Rob-PC
Memory Usage 92 MB
Peak Memory Usage 149 MB
chrome.exe
Process ID 5708
User Rob
Domain Rob-PC
Memory Usage 103 MB
Peak Memory Usage 142 MB
csrss.exe
Process ID 652
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\csrss.exe
Memory Usage 10 MB
Peak Memory Usage 22 MB
csrss.exe
Process ID 576
User SYSTEM
Domain NT AUTHORITY
Memory Usage 1.65 MB
Peak Memory Usage 4.56 MB
deskpins.exe
Process ID 2364
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\DeskPins\DeskPins.exe
Memory Usage 604 KB
Peak Memory Usage 4.33 MB
dllhost.exe
Process ID 864
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\DllHost.exe
Memory Usage 6.35 MB
Peak Memory Usage 6.35 MB
dllhost.exe
Process ID 4180
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.41 MB
Peak Memory Usage 5.41 MB
dwm.exe
Process ID 2348
User Rob
Domain Rob-PC
Path C:\Windows\system32\Dwm.exe
Memory Usage 36 MB
Peak Memory Usage 50 MB
explorer.exe
Process ID 2452
User Rob
Domain Rob-PC
Path C:\Windows\Explorer.EXE
Memory Usage 37 MB
Peak Memory Usage 72 MB
heciserver.exe
Process ID 1620
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Intel\iCLS Client\HeciServer.exe
Memory Usage KB
Peak Memory Usage 6.02 MB
iastordatamgrsvc.exe
Process ID 4916
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
Memory Usage 4.72 MB
Peak Memory Usage 21 MB
iastoricon.exe
Process ID 2444
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
Memory Usage 9.20 MB
iusb3mon.exe
Process ID 3156
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe
Memory Usage 1.68 MB
Peak Memory Usage 5.39 MB
jhi_service.exe
Process ID 1684
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
Memory Usage 156 KB
Peak Memory Usage 5.11 MB
lms.exe
Process ID 2816
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
Memory Usage 1.94 MB
Peak Memory Usage 4.89 MB
lsass.exe
Process ID 772
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\lsass.exe
Memory Usage 4.78 MB
Peak Memory Usage 11 MB
lsm.exe
Process ID 780
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\lsm.exe
Memory Usage 1.48 MB
Peak Memory Usage 4.61 MB
mom.exe
Process ID 3676
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\MOM.exe
Memory Usage 3.55 MB
Peak Memory Usage 30 MB
presentationfontcache.exe
Process ID 4228
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\Microsoft.Net\Framework64\v3.0\WPF\PresentationFontCache.exe
Memory Usage 1.18 MB
Peak Memory Usage 17 MB
rtkngui64.exe
Process ID 2944
User Rob
Domain Rob-PC
Path C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
Memory Usage 4.97 MB
Peak Memory Usage 12 MB
rundll32.exe
Process ID 3412
User Rob
Domain Rob-PC
Path C:\Windows\SysWOW64\rundll32.exe
Memory Usage 7.05 MB
Peak Memory Usage 7.10 MB
searchindexer.exe
Process ID 2024
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\SearchIndexer.exe
Memory Usage 9.75 MB
services.exe
Process ID 744
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\services.exe
Memory Usage 5.13 MB
Peak Memory Usage 9.54 MB
sidebar.exe
Process ID 4428
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Windows Sidebar\sidebar.exe
Memory Usage 7.29 MB
Peak Memory Usage 33 MB
skype.exe
Process ID 2952
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Skype\Phone\Skype.exe
Memory Usage 75 MB
Peak Memory Usage 129 MB
smss.exe
Process ID 416
User SYSTEM
Domain NT AUTHORITY
Path \SystemRoot\System32\smss.exe
Memory Usage 68 KB
Peak Memory Usage 1.39 MB
speccy64.exe
Process ID 4208
User Rob
Domain Rob-PC
Path C:\Program Files\Speccy\Speccy64.exe
Memory Usage 20 MB
Peak Memory Usage 20 MB
spoolsv.exe
Process ID 1396
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\spoolsv.exe
Memory Usage 3.49 MB
Peak Memory Usage 13 MB
sppsvc.exe
Process ID 4380
User NETWORK SERVICE
Domain NT AUTHORITY
Path C:\Windows\system32\sppsvc.exe
Memory Usage 2.32 MB
Peak Memory Usage 14 MB
svchost.exe
Process ID 880
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\svchost.exe
Memory Usage 4.13 MB
Peak Memory Usage 10 MB
svchost.exe
Process ID 960
Domain NT AUTHORITY
Memory Usage 4.83 MB
Peak Memory Usage 8.61 MB
svchost.exe
Process ID 584
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\svchost.exe
Memory Usage 12 MB
svchost.exe
Process ID 820
User SYSTEM
Domain NT AUTHORITY
Memory Usage 241 MB
Peak Memory Usage 260 MB
svchost.exe
Process ID 192
User SYSTEM
Domain NT AUTHORITY
Memory Usage 31 MB
Peak Memory Usage 145 MB
svchost.exe
Process ID 1252
Domain NT AUTHORITY
Memory Usage 10 MB
Peak Memory Usage 16 MB
svchost.exe
Process ID 1428
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.11 MB
Peak Memory Usage 49 MB
svchost.exe
Process ID 2584
Domain NT AUTHORITY
Memory Usage 2.61 MB
Peak Memory Usage 6.32 MB
svchost.exe
Process ID 1156
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.02 MB
svchost.exe
Process ID 4800
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 144 KB
Peak Memory Usage 5.44 MB
symcpcculaunchsvc.exe
Process ID 4548
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Norton PC Checkup\Engine\2.0.15.96\SymcPCCULaunchSvc.exe
Memory Usage 184 KB
Peak Memory Usage 7.61 MB
system
Process ID 4
system idle process
Process ID 0
taskhost.exe
Process ID 2264
User Rob
Domain Rob-PC
Path C:\Windows\system32\taskhost.exe
Memory Usage 5.62 MB
Peak Memory Usage 8.13 MB
uns.exe
Process ID 4832
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
Memory Usage 2.60 MB
Peak Memory Usage 9.86 MB
updatechecker.exe
Process ID 2972
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\Dxtory Software\Dxtory2.0\UpdateChecker.exe
Memory Usage 16 MB
Peak Memory Usage 54 MB
wininit.exe
Process ID 636
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\wininit.exe
Memory Usage 152 KB
Peak Memory Usage 5.21 MB
winlogon.exe
Process ID 708
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\winlogon.exe
Memory Usage 1.30 MB
Peak Memory Usage 9.07 MB
wmiprvse.exe
Process ID 5280
Domain NT AUTHORITY
Path C:\Windows\system32\wbem\wmiprvse.exe
Memory Usage 10 MB
wow.exe
Process ID 5496
User Rob
Domain Rob-PC
Path C:\Program Files (x86)\World of Warcraft\Wow.exe
Memory Usage 1.02 GB
Peak Memory Usage 1.06 GB
wuauclt.exe
Process ID 2260
User Rob
Domain Rob-PC
Path C:\Windows\system32\wuauclt.exe
Memory Usage 1.12 MB
Hotfixes
15/07/2012 Hotfix for Windows (KB2505454)
Fix for KB2505454
14/07/2012 Security Update for Windows 7 for x64-based Systems (KB2621440)
A security issue has been identified that could allow an unauthenticated
remote attacker to compromise your system and gain control over
it. You can help protect your system by installing this update
from Microsoft. After you install this update, you may have to
restart your system.
14/07/2012 Windows Update Agent 7.6.7600.256
The Windows Update Agent enables your computer to search for
and install updates from an update service. The agent can automatically
update itself as needed to communicate with the update service
when Windows searches for new updates.
14/07/2012 Update for Windows (KB958488)
Microsoft .NET Framework 4.0 Shared
System Folders
Path for burning CD C:\Users\Rob\AppData\Local\Microsoft\Windows\Burn\Burn
Application Data C:\ProgramData
Public Desktop C:\Users\Public\Desktop
Documents C:\Users\Public\Documents
Global Favorites C:\Users\Rob\Favorites
Music C:\Users\Public\Music
Pictures C:\Users\Public\Pictures
Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Templates C:\ProgramData\Microsoft\Windows\Templates
Videos C:\Users\Public\Videos
Cookies C:\Users\Rob\AppData\Roaming\Microsoft\Windows\Cookies
Desktop C:\Users\Rob\Desktop
Physical Desktop C:\Users\Rob\Desktop
User Favorites C:\Users\Rob\Favorites
Fonts C:\Windows\Fonts
Internet History C:\Users\Rob\AppData\Local\Microsoft\Windows\History
Temporary Internet Files C:\Users\Rob\AppData\Local\Microsoft\Windows\Temporary Internet Files
Local Application Data C:\Users\Rob\AppData\Local
Windows directory C:\Windows
Windows/System C:\Windows\system32
Program Files C:\Program Files
Security Options
Accounts: Administrator account status Disabled
Accounts: Guest account status Disabled
Accounts: Limit local account use of blank passwords to console logon only Enabled
Accounts: Rename administrator account Administrator
Accounts: Rename guest account Guest
Audit: Audit the access of global system objects Disabled
Audit: Audit the use of Backup and Restore privilege Disabled
Audit: Force audit policy subcategory settings (Windows Vista or later) to override audit policy category settings Not Defined
Audit: Shut down system immediately if unable to log security audits Disabled
DCOM: Machine Access Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
DCOM: Machine Launch Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
Devices: Allow undock without having to log on Enabled
Devices: Allowed to format and eject removable media Not Defined
Devices: Prevent users from installing printer drivers Disabled
Devices: Restrict CD-ROM access to locally logged-on user only Not Defined
Devices: Restrict floppy access to locally logged-on user only Not Defined
Domain controller: Allow server operators to schedule tasks Not Defined
Domain controller: LDAP server signing requirements Not Defined
Domain controller: Refuse machine account password changes Not Defined
Domain member: Digitally encrypt or sign secure channel data (always) Enabled
Domain member: Digitally encrypt secure channel data (when possible) Enabled
Domain member: Digitally sign secure channel data (when possible) Enabled
Domain member: Disable machine account password changes Disabled
Domain member: Maximum machine account password age 30 days
Domain member: Require strong (Windows 2000 or later) session key Enabled
Interactive logon: Display user information when the session is locked Not Defined
Interactive logon: Do not display last user name Disabled
Interactive logon: Do not require CTRL+ALT+DEL Not Defined
Interactive logon: Message text for users attempting to log on Not Defined
Interactive logon: Message title for users attempting to log on
Interactive logon: Number of previous logons to cache (in case domain controller is not available) 10 logons
Interactive logon: Prompt user to change password before expiration 5 days
Interactive logon: Require Domain Controller authentication to unlock workstation Disabled
Interactive logon: Require smart card Disabled
Interactive logon: Smart card removal behavior No Action
Microsoft network client: Digitally sign communications (always) Disabled
Microsoft network client: Digitally sign communications (if server agrees) Enabled
Microsoft network client: Send unencrypted password to third-party SMB servers Disabled
Microsoft network server: Amount of idle time required before suspending session 15 minutes
Microsoft network server: Digitally sign communications (always) Disabled
Microsoft network server: Digitally sign communications (if client agrees) Disabled
Microsoft network server: Disconnect clients when logon hours expire Enabled
Microsoft network server: Server SPN target name validation level Not Defined
Network access: Allow anonymous SID/Name translation Disabled
Network access: Do not allow anonymous enumeration of SAM accounts Enabled
Network access: Do not allow anonymous enumeration of SAM accounts and shares Disabled
Network access: Do not allow storage of passwords and credentials for network authentication Disabled
Network access: Let Everyone permissions apply to anonymous users Disabled
Network access: Named Pipes that can be accessed anonymously
Network access: Remotely accessible registry paths System\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Server Applications,Software\Microsoft\Windows NT\CurrentVersion
Network access: Remotely accessible registry paths and sub-paths System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Services\Eventlog,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion\Print,Software\Microsoft\Windows NT\CurrentVersion\Windows,System\CurrentControlSet\Control\ContentIndex,System\CurrentControlSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration,Software\Microsoft\Windows NT\CurrentVersion\Perflib,System\CurrentControlSet\Services\SysmonLog
Network access: Restrict anonymous access to Named Pipes and Shares Enabled
Network access: Shares that can be accessed anonymously Not Defined
Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
Network security: Allow Local System to use computer identity for NTLM Not Defined
Network security: Allow LocalSystem NULL session fallback Not Defined
Network Security: Allow PKU2U authentication requests to this computer to use online identities Not Defined
Network security: Configure encryption types allowed for Kerberos Not Defined
Network security: Do not store LAN Manager hash value on next password change Enabled
Network security: Force logoff when logon hours expire Disabled
Network security: LAN Manager authentication level Not Defined
Network security: LDAP client signing requirements Negotiate signing
Network security: Minimum session security for NTLM SSP based (including secure RPC) clients Require 128-bit encryption
Network security: Minimum session security for NTLM SSP based (including secure RPC) servers Require 128-bit encryption
Network security: Restrict NTLM: Add remote server exceptions for NTLM authentication Not Defined
Network security: Restrict NTLM: Add server exceptions in this domain Not Defined
Network security: Restrict NTLM: Audit Incoming NTLM Traffic Not Defined
Network security: Restrict NTLM: Audit NTLM authentication in this domain Not Defined
Network security: Restrict NTLM: Incoming NTLM traffic Not Defined
Network security: Restrict NTLM: NTLM authentication in this domain Not Defined
Network security: Restrict NTLM: Outgoing NTLM traffic to remote servers Not Defined
Recovery console: Allow automatic administrative logon Disabled
Recovery console: Allow floppy copy and access to all drives and all folders Disabled
Shutdown: Allow system to be shut down without having to log on Enabled
Shutdown: Clear virtual memory pagefile Disabled
System cryptography: Force strong key protection for user keys stored on the computer Not Defined
System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing Disabled
System objects: Require case insensitivity for non-Windows subsystems Enabled
System objects: Strengthen default permissions of internal system objects (e.g. Symbolic Links) Enabled
System settings: Optional subsystems Posix
System settings: Use Certificate Rules on Windows Executables for Software Restriction Policies Disabled
User Account Control: Admin Approval Mode for the Built-in Administrator account Disabled
User Account Control: Allow UIAccess applications to prompt for elevation without using the secure desktop Disabled
User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode Prompt for consent for non-Windows binaries
User Account Control: Behavior of the elevation prompt for standard users Prompt for credentials
User Account Control: Detect application installations and prompt for elevation Enabled
User Account Control: Only elevate executables that are signed and validated Disabled
User Account Control: Only elevate UIAccess applications that are installed in secure locations Enabled
User Account Control: Run all administrators in Admin Approval Mode Enabled
User Account Control: Switch to the secure desktop when prompting for elevation Enabled
User Account Control: Virtualize file and registry write failures to per-user locations Enabled
Services
Running AMD External Events Utility
Running Application Information
Running Base Filtering Engine
Running COM+ Event System
Running Common Client Job Manager Service
Running Cryptographic Services
Running DCOM Server Process Launcher
Running Desktop Window Manager Session Manager
Running DHCP Client
Running Diagnostic Policy Service
Running Diagnostic Service Host
Running Distributed Link Tracking Client
Running DNS Client
Running Group Policy Client
Running Human Interface Device Access
Running IKE and AuthIP IPsec Keying Modules
Running Intel(R) Capability Licensing Service Interface
Running Intel(R) Dynamic Application Loader Host Interface Service
Running Intel(R) Management and Security Application Local Management Service
Running Intel(R) Management and Security Application User Notification Service
Running Intel(R) Rapid Storage Technology
Running IP Helper
Running IPsec Policy Agent
Running Multimedia Class Scheduler
Running Network Connections
Running Network List Service
Running Network Location Awareness
Running Network Store Interface Service
Running Norton Internet Security
Running Norton PC Checkup Application Launcher
Running Plug and Play
Running Power
Running Print Spooler
Running Program Compatibility Assistant Service
Running Protected Storage
Running Remote Procedure Call (RPC)
Running RPC Endpoint Mapper
Running Security Accounts Manager
Running Security Center
Running Server
Running Shell Hardware Detection
Running Software Protection
Running SPP Notification Service
Running Superfetch
Running System Event Notification Service
Running Task Scheduler
Running TCP/IP NetBIOS Helper
Running Themes
Running User Profile Service
Running Windows Audio
Running Windows Audio Endpoint Builder
Running Windows Event Log
Running Windows Firewall
Running Windows Font Cache Service
Running Windows Management Instrumentation
Running Windows Presentation Foundation Font Cache 3.0.0.0
Running Windows Search
Running Windows Update
Running WinHTTP Web Proxy Auto-Discovery Service
Running Workstation
Stopped ActiveX Installer (AxInstSV)
Stopped Adaptive Brightness
Stopped Adobe Flash Player Update Service
Stopped Application Experience
Stopped Application Identity
Stopped Application Layer Gateway Service
Stopped ASP.NET State Service
Stopped Background Intelligent Transfer Service
Stopped BitLocker Drive Encryption Service
Stopped Block Level Backup Engine Service
Stopped Bluetooth Support Service
Stopped Certificate Propagation
Stopped CNG Key Isolation
Stopped COM+ System Application
Stopped Computer Browser
Stopped Credential Manager
Stopped Diagnostic System Host
Stopped Disk Defragmenter
Stopped Distributed Transaction Coordinator
Stopped Encrypting File System (EFS)
Stopped Extensible Authentication Protocol
Stopped Fax
Stopped Function Discovery Provider Host
Stopped Function Discovery Resource Publication
Stopped Google Update Service (gupdate)
Stopped Google Update Service (gupdatem)
Stopped Health Key and Certificate Management
Stopped HomeGroup Listener
Stopped HomeGroup Provider
Stopped Interactive Services Detection
Stopped Internet Connection Sharing (ICS)
Stopped KtmRm for Distributed Transaction Coordinator
Stopped Link-Layer Topology Discovery Mapper
Stopped Media Center Extender Service
Stopped Microsoft .NET Framework NGEN v2.0.50727_X64
Stopped Microsoft .NET Framework NGEN v2.0.50727_X86
Stopped Microsoft .NET Framework NGEN v4.0.30319_X64
Stopped Microsoft .NET Framework NGEN v4.0.30319_X86
Stopped Microsoft iSCSI Initiator Service
Stopped Microsoft Software Shadow Copy Provider
Stopped Net.Msmq Listener Adapter
Stopped Net.Pipe Listener Adapter
Stopped Net.Tcp Listener Adapter
Stopped Net.Tcp Port Sharing Service
Stopped Netlogon
Stopped Network Access Protection Agent
Stopped Parental Controls
Stopped Peer Name Resolution Protocol
Stopped Peer Networking Grouping
Stopped Peer Networking Identity Manager
Stopped Performance Counter DLL Host
Stopped Performance Logs & Alerts
Stopped PnP-X IP Bus Enumerator
Stopped PNRP Machine Name Publication Service
Stopped Portable Device Enumerator Service
Stopped Problem Reports and Solutions Control Panel Support
Stopped Quality Windows Audio Video Experience
Stopped Remote Access Auto Connection Manager
Stopped Remote Access Connection Manager
Stopped Remote Desktop Configuration
Stopped Remote Desktop Services
Stopped Remote Procedure Call (RPC) Locator
Stopped Remote Registry
Stopped Routing and Remote Access
Stopped Secondary Logon
Stopped Secure Socket Tunneling Protocol Service
Stopped Skype Updater
Stopped Smart Card
Stopped Smart Card Removal Policy
Stopped SNMP Trap
Stopped SSDP Discovery
Stopped Tablet PC Input Service
Stopped Telephony
Stopped Thread Ordering Server
Stopped TPM Base Services
Stopped UPnP Device Host
Stopped Virtual Disk
Stopped Volume Shadow Copy
Stopped WebClient
Stopped Windows Backup
Stopped Windows Biometric Service
Stopped Windows CardSpace
Stopped Windows Color System
Stopped Windows Connect Now - Config Registrar
Stopped Windows Defender
Stopped Windows Driver Foundation - User-mode Driver Framework
Stopped Windows Error Reporting Service
Stopped Windows Event Collector
Stopped Windows Image Acquisition (WIA)
Stopped Windows Installer
Stopped Windows Media Center Receiver Service
Stopped Windows Media Center Scheduler Service
Stopped Windows Media Player Network Sharing Service
Stopped Windows Modules Installer
Stopped Windows Remote Management (WS-Management)
Stopped Windows Time
Stopped Wired AutoConfig
Stopped WLAN AutoConfig
Stopped WMI Performance Adapter
Stopped WWAN AutoConfig
Device Tree
ACPI x64-based PC
Microsoft ACPI-Compliant System
ACPI Power Button
Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
ACPI Fan
ACPI Fan
ACPI Fan
ACPI Fan
ACPI Fan
ACPI Thermal Zone
ACPI Thermal Zone
Microsoft Windows Management Interface for ACPI
ACPI Fixed Feature Button
PCI bus
Xeon(R) processor E3-1200 v2/3rd Gen Core processor DRAM Controller - 0150
Intel(R) Management Engine Interface
Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
System board
Motherboard resources
Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Generic PnP Monitor
High Definition Audio Controller
AMD High Definition Audio Device
Intel(R) USB 3.0 Root Hub
Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
USB Root Hub
Generic USB Hub
Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
Realtek PCIe GBE Family Controller
Intel(R) 82801 PCI Bridge - 244E
PCI standard PCI-to-PCI bridge
Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 7 - 1E1C
Network Controller
Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
USB Root Hub
Generic USB Hub
USB Composite Device
USB Input Device
HID Keyboard Device
USB Input Device
HID-compliant mouse
HID-compliant consumer control device
USB Input Device
HID Keyboard Device
USB Input Device
HID-compliant mouse
USB Input Device
HID-compliant device
Intel(R) Z77 Express Chipset LPC Controller - 1E44
Direct memory access controller
Intel(R) 82802 Firmware Hub Device
High precision event timer
Programmable interrupt controller
System CMOS/real time clock
System timer
Intel(R) Watchdog Timer Driver (Intel(R) WDT)
Numeric data processor
Communications Port (COM1)
Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller
ST500DM002-1BD142
CPU
Intel Core i7 3770K
Cores 4
Threads 8
Name Intel Core i7 3770K
Code Name Ivy Bridge
Package Socket 1155 LGA
Technology 22nm
Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Family 6
Extended Family 6
Model A
Extended Model 3A
Stepping 9
Revision E1
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64
Virtualization Supported, Disabled
Hyperthreading Supported, Enabled
Bus Speed 100.0 MHz
Stock Core Speed 3500 MHz
Stock Bus Speed 100 MHz
Average Temperature 41 °C
Caches
L1 Data Cache Size 4 x 32 KBytes
L1 Instructions Cache Size 4 x 32 KBytes
L2 Unified Cache Size 4 x 256 KBytes
L3 Unified Cache Size 8192 KBytes
Core 0
Core Speed 3700.2 MHz
Multiplier x 37.0
Bus Speed 100.0 MHz
Temperature 37 °C
Thread 1
APIC ID 0
Thread 2
APIC ID 1
Core 1
Multiplier x 37.0
Bus Speed 100.0 MHz
Temperature 42 °C
Thread 1
APIC ID 2
Thread 2
APIC ID 3
Core 2
Multiplier x 37.0
Bus Speed 100.0 MHz
Temperature 40 °C
Thread 1
APIC ID 4
Thread 2
APIC ID 5
Core 3
Multiplier x 37.0
Bus Speed 100.0 MHz
Temperature 44 °C
Thread 1
APIC ID 6
Thread 2
APIC ID 7
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR3
Size 32768 MBytes
Channels # Dual
DRAM Frequency 666.7 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 23 %
Total Physical 16 GB
Available Physical 12 GB
Total Virtual 32 GB
Available Virtual 27 GB
SPD
Number Of SPD Modules 4
Slot #1
Type DDR3
Size 8192 MBytes
Manufacturer Corsair
Max Bandwidth PC3-10700 (667 MHz)
Part Number CMZ32GX3M4X1600C10
SPD Ext. EPP
XMP--2
Frequency
JEDEC #3
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 33
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 26
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 22
Voltage 1.500 V
Slot #2
Type DDR3
Size 8192 MBytes
SPD Ext. EPP
XMP--2
Frequency
JEDEC #3
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 33
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 26
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 22
Voltage 1.500 V
Slot #3
Type DDR3
Size 8192 MBytes
SPD Ext. EPP
XMP--2
Frequency
JEDEC #3
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 33
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 26
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 22
Voltage 1.500 V
Slot #4
Type DDR3
Size 8192 MBytes
SPD Ext. EPP
XMP--2
Frequency
JEDEC #3
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 25
tRC 33
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 26
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 17
tRC 22
Voltage 1.500 V
Motherboard
Manufacturer ASUSTeK COMPUTER INC.
Model P8Z77-V LX (LGA1155)
Version System Version
Chipset Vendor Intel
Chipset Model Ivy Bridge
Chipset Revision 09
Southbridge Vendor Intel
Southbridge Model Z77
Southbridge Revision 04
System Temperature 27 °C
BIOS
Brand American Megatrends Inc.
Version 0610
Date 05/08/2012
Voltage
CPU CORE 1.088 V
MEMORY CONTROLLER 1.008 V
+3.3V 3.376 V
+5V 5.040 V
+12V 7.137 V
VIN6 0.976 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCIEX16_1
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCIEX1_1
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Bus Width 32 bit
Slot Designation PCIEX1_2
Slot Number 2
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI1
Slot Number 3
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI2
Slot Number 4
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI3
Slot Number 5
Slot PCI-E
Slot Type PCI-E
Bus Width 32 bit
Slot Designation PCIEX16_2
Slot Number 6
Graphics
Monitor
Name SAMSUNG on AMD Radeon HD 7800 Series
Current Resolution 1360x768 pixels
Work Resolution 1360x738 pixels
State enabled, primary, output devices support
Monitor Width 1360
Monitor Height 768
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Memory 4294965248 MB
Memory type 2
Driver version 8.950.0.0
OpenGL
Version 4.2.11554 Compatibility Profile Context
Vendor ATI Technologies Inc.
Renderer AMD Radeon HD 7800 Series
GLU Version 1.2.2.0 Microsoft Corporation
Values
GL_MAX_LIGHTS 8
GL_MAX_TEXTURE_SIZE 16384
GL_MAX_TEXTURE_STACK_DEPTH 10
GL Extensions
GL_AMDX_debug_output
GL_AMD_blend_minmax_factor
GL_AMD_conservative_depth
GL_AMD_debug_output
GL_AMD_depth_clamp_separate
GL_AMD_draw_buffers_blend
GL_AMD_multi_draw_indirect
GL_AMD_name_gen_delete
GL_AMD_performance_monitor
GL_AMD_pinned_memory
GL_AMD_sample_positions
GL_AMD_seamless_cubemap_per_texture
GL_AMD_shader_stencil_export
GL_AMD_shader_trace
GL_AMD_stencil_operation_extended
GL_AMD_texture_cube_map_array
GL_AMD_texture_texture4
GL_AMD_transform_feedback3_lines_triangles
GL_ARB_ES2_compatibility
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_color_buffer_float
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_explicit_attrib_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_provoking_vertex
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_image_load_store
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_stencil_export
GL_ARB_shader_subroutine
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_shadow_ambient
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_snorm
GL_ARB_texture_storage
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_envmap_bumpmap
GL_ATI_fragment_shader
GL_ATI_meminfo
GL_ATI_separate_stencil
GL_ATI_texture_compression_3dc
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_copy_buffer
GL_EXT_copy_texture
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_histogram
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_subtexture
GL_EXT_texgen_reflection
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_bptc
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_IBM_texture_mirrored_repeat
GL_KTX_buffer_region
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_explicit_multisample
GL_NV_float_buffer
GL_NV_half_float
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
WGL_EXT_swap_control
GL_EXT_bgra
Hard Drives
ST500DM002-1BD142
Manufacturer Seagate
Heads 16
Cylinders 16383
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number Z2AMFY3F
LBA Size 48-bit LBA
Power On Count 34 times
Power On Time 11.3 days
Speed, Expressed in Revolutions Per Minute (rpm) 7200
Features S.M.A.R.T., AAM, NCQ
Transfer Mode SATA III
Interface SATA
Capacity 466GB
Real size 500,107,862,016 bytes
RAID Type None
S.M.A.R.T
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter E:
File System NTFS
Volume Serial Number AC854E07
Size 99MB
Used Space 46MB (47%)
Free Space 53MB (53%)
Partition 1
Partition ID Disk #0, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number 3E86B7EE
Size 466GB
Used Space 104GB (23%)
Free Space 362GB (77%)
Optical Drives
Media Type DVD Writer
Name Optiarc DVD RW AD-5280S
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive D:
DriveIntegrity TRUE
Media Loaded TRUE
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target Id 1
Size 504 MB
Status OK
Transfer Rate 718 KB/S
Volume Name AMD_022012
Volume Serial Number 90B2041C
Audio
Sound Cards
Playback Devices
Speakers (Realtek High Definition Audio) (default)
Realtek Digital Output(Optical) (Realtek High Definition Audio)
SAMSUNG (AMD High Definition Audio Device)
Realtek Digital Output (Realtek High Definition Audio)
Recording Devices
Stereo Mix (Realtek High Definition Audio)
Microphone (Realtek High Definition Audio) (default)
Speaker Configuration
Speaker type Stereo
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Unknown
Location USB Input Device
Driver
Date 6-21-2006
Version 6.1.7601.17514
File C:\Windows\system32\DRIVERS\kbdhid.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
HID Keyboard Device
Vendor Baldor Electric Company
Driver
Date 6-21-2006
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Vendor Unknown
Driver
Date 6-21-2006
Version 6.1.7600.16385
File C:\Windows\system32\DRIVERS\mouhid.sys
File C:\Windows\system32\DRIVERS\mouclass.sys
HID-compliant mouse
Device Kind Mouse
Driver
Date 6-21-2006
Printers
Fax
Printer Port SHRFAX:
Print Processor winprint
Availability Always
Priority 1
Duplex None
Print Quality 200 * 200 dpi Monochrome
Status Unknown
Driver
Driver Name Microsoft Shared Fax Driver (v4.00)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\FXSDRV.DLL
Microsoft XPS Document Writer
Printer Port XPSPort:
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Color
Status Unknown
Driver
Driver Name Microsoft XPS Document Writer (v6.00)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\mxdwdrv.dll
PDFCreator (Default Printer)
Printer Port PDFCreator:
Availability Always
Priority 1
Duplex None
Status Unknown
Driver
Driver Name PDFCreator (v5.02)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\PSCRIPT5.DLL
Network
You are connected to the internet
Connected through Realtek PCIe GBE Family Controller
IP Address 192.168.1.80
Subnet mask 255.255.255.0
Gateway server 192.168.1.254
Preferred DNS server 192.168.1.254
DHCP Enabled
DHCP server 192.168.1.254
External IP Address 109.153.144.133
Adapter Type Ethernet
NetBIOS over TCP/IP Enabled via DHCP
NETBIOS Node Type Hybrid node
Link Speed 8 kbps
Computer Name
NetBIOS Name ROB-PC
DNS Name Rob-PC
Domain Name Rob-PC
Remote Desktop
Console
State Active
Domain Rob-PC
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout 60000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout 30000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Disabled
File and Printer Sharing Disabled
Simple File Sharing Disabled
Administrative Shares Enabled
Adapters List
Network Shares
No network shares
Current TCP Connections
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (1816)
Local 192.168.1.80:55013 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:55454 ESTABLISHED Remote 213.120.161.160:80 (Querying... ) (HTTP)
Local 192.168.1.80:55456 ESTABLISHED Remote 173.194.34.92:80 (Querying... ) (HTTP)
Local 192.168.1.80:55469 ESTABLISHED Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:55486 ESTABLISHED Remote 173.194.78.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:55487 ESTABLISHED Remote 173.194.78.94:80 (Querying... ) (HTTP)
Local 192.168.1.80:55493 ESTABLISHED Remote 173.194.34.71:80 (Querying... ) (HTTP)
Local 192.168.1.80:55494 ESTABLISHED Remote 173.194.34.69:80 (Querying... ) (HTTP)
Local 192.168.1.80:55495 ESTABLISHED Remote 173.194.34.69:80 (Querying... ) (HTTP)
Local 192.168.1.80:55542 ESTABLISHED Remote 173.194.34.65:80 (Querying... ) (HTTP)
Local 192.168.1.80:55497 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55498 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55500 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55501 ESTABLISHED Remote 173.194.34.70:80 (Querying... ) (HTTP)
Local 192.168.1.80:55502 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55503 ESTABLISHED Remote 173.194.34.66:80 (Querying... ) (HTTP)
Local 192.168.1.80:55504 ESTABLISHED Remote 173.194.34.66:80 (Querying... ) (HTTP)
Local 192.168.1.80:55505 ESTABLISHED Remote 173.194.34.70:80 (Querying... ) (HTTP)
Local 192.168.1.80:55508 ESTABLISHED Remote 173.194.34.91:80 (Querying... ) (HTTP)
Local 192.168.1.80:55509 ESTABLISHED Remote 173.194.34.92:80 (Querying... ) (HTTP)
Local 192.168.1.80:55510 ESTABLISHED Remote 173.194.34.66:80 (Querying... ) (HTTP)
Local 192.168.1.80:55511 ESTABLISHED Remote 173.194.34.66:80 (Querying... ) (HTTP)
Local 192.168.1.80:55512 ESTABLISHED Remote 173.194.34.70:80 (Querying... ) (HTTP)
Local 192.168.1.80:55513 ESTABLISHED Remote 173.194.34.70:80 (Querying... ) (HTTP)
Local 192.168.1.80:55514 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55515 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55516 ESTABLISHED Remote 173.194.34.90:80 (Querying... ) (HTTP)
Local 192.168.1.80:55517 ESTABLISHED Remote 173.194.34.124:80 (Querying... ) (HTTP)
Local 192.168.1.80:55518 ESTABLISHED Remote 2.19.239.139:80 (Querying... ) (HTTP)
Local 192.168.1.80:55519 ESTABLISHED Remote 173.194.34.79:80 (Querying... ) (HTTP)
Local 192.168.1.80:55520 ESTABLISHED Remote 88.221.94.234:80 (Querying... ) (HTTP)
Local 192.168.1.80:55522 ESTABLISHED Remote 173.194.34.79:80 (Querying... ) (HTTP)
Local 192.168.1.80:55523 ESTABLISHED Remote 173.194.34.69:80 (Querying... ) (HTTP)
Local 192.168.1.80:55525 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55529 ESTABLISHED Remote 173.194.34.67:80 (Querying... ) (HTTP)
Local 192.168.1.80:55530 ESTABLISHED Remote 173.194.34.67:80 (Querying... ) (HTTP)
Local 192.168.1.80:54996 ESTABLISHED Remote 217.41.223.224:80 (Querying... ) (HTTP)
Local 192.168.1.80:55496 ESTABLISHED Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:52016 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:52139 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:52533 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:53346 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:55543 ESTABLISHED Remote 74.125.4.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:55545 ESTABLISHED Remote 173.194.34.77:80 (Querying... ) (HTTP)
Local 192.168.1.80:55546 ESTABLISHED Remote 173.194.34.77:80 (Querying... ) (HTTP)
Local 192.168.1.80:55547 ESTABLISHED Remote 173.194.34.71:80 (Querying... ) (HTTP)
Local 192.168.1.80:54543 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:54652 ESTABLISHED Remote 207.46.125.85:443 (Querying... ) (HTTPS)
Local 192.168.1.80:55550 ESTABLISHED Remote 207.171.163.24:443 (Querying... ) (HTTPS)
Local 192.168.1.80:55551 ESTABLISHED Remote 173.194.34.65:80 (Querying... ) (HTTP)
Local 192.168.1.80:54743 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:54888 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:54934 FIN-WAIT-2 Remote 159.253.157.103:80 (Querying... ) (HTTP)
Local 192.168.1.80:54998 ESTABLISHED Remote 216.239.116.48:80 (Querying... ) (HTTP)
Local 192.168.1.80:55570 ESTABLISHED Remote 207.46.125.85:443 (Querying... ) (HTTPS)
C:\Program Files (x86)\Skype\Phone\Skype.exe (2952)
Local 192.168.1.80:50793 ESTABLISHED Remote 78.141.179.12:12350 (Querying... )
Local 192.168.1.80:50806 ESTABLISHED Remote 65.54.61.173:443 (Querying... ) (HTTPS)
Local 192.168.1.80:50792 ESTABLISHED Remote 213.199.179.153:40027 (Querying... )
Local 0.0.0.0:80 (HTTP) LISTEN
Local 0.0.0.0:24184 LISTEN
Local 0.0.0.0:443 (HTTPS) LISTEN
C:\Program Files (x86)\World of Warcraft\Wow.exe (5496)
Local 192.168.1.80:55054 ESTABLISHED Remote 213.248.127.130:1119 (Querying... )
Local 192.168.1.80:55056 ESTABLISHED Remote 195.12.244.165:3724 (Querying... )
Local 192.168.1.80:55057 ESTABLISHED Remote 195.12.244.163:3724 (Querying... )
System Process
Local 192.168.1.80:55394 TIME-WAIT Remote 213.120.161.202:80 (Querying... ) (HTTP)
Local 192.168.1.80:55539 TIME-WAIT Remote 94.127.74.180:80 (Querying... ) (HTTP)
Local 192.168.1.80:55535 TIME-WAIT Remote 67.215.233.132:80 (Querying... ) (HTTP)
Local 192.168.1.80:55540 TIME-WAIT Remote 94.127.74.180:80 (Querying... ) (HTTP)
Local 192.168.1.80:55534 TIME-WAIT Remote 67.215.233.132:80 (Querying... ) (HTTP)
Local 192.168.1.80:55424 TIME-WAIT Remote 65.55.239.188:443 (Querying... ) (HTTPS)
Local 192.168.1.80:55541 TIME-WAIT Remote 94.127.74.180:80 (Querying... ) (HTTP)
Local 192.168.1.80:55549 TIME-WAIT Remote 94.127.74.120:80 (Querying... ) (HTTP)
Local 192.168.1.80:55552 TIME-WAIT Remote 173.194.34.91:80 (Querying... ) (HTTP)
Local 192.168.1.80:55553 TIME-WAIT Remote 173.194.34.91:80 (Querying... ) (HTTP)
Local 192.168.1.80:55554 TIME-WAIT Remote 173.194.34.124:80 (Querying... ) (HTTP)
Local 192.168.1.80:55555 TIME-WAIT Remote 173.194.34.124:80 (Querying... ) (HTTP)
Local 192.168.1.80:55533 TIME-WAIT Remote 67.215.233.132:80 (Querying... ) (HTTP)
Local 192.168.1.80:55395 TIME-WAIT Remote 213.120.161.202:80 (Querying... ) (HTTP)
Local 192.168.1.80:55532 TIME-WAIT Remote 67.215.233.132:80 (Querying... ) (HTTP)
Local 192.168.1.80:51792 TIME-WAIT Remote 92.122.123.25:80 (Querying... ) (HTTP)
Local 192.168.1.80:51982 TIME-WAIT Remote 199.9.252.172:443 (Querying... ) (HTTPS)
Local 192.168.1.80:55396 TIME-WAIT Remote 213.120.161.202:80 (Querying... ) (HTTP)
Local 192.168.1.80:55397 TIME-WAIT Remote 213.120.161.202:80 (Querying... ) (HTTP)
Local 192.168.1.80:55398 TIME-WAIT Remote 213.120.161.202:80 (Querying... ) (HTTP)
Local 192.168.1.80:55422 TIME-WAIT Remote 94.245.117.47:443 (Querying... ) (HTTPS)
Local 192.168.1.80:55423 TIME-WAIT Remote 94.245.117.47:443 (Querying... ) (HTTPS)
Local 192.168.1.80:55548 TIME-WAIT Remote 94.127.79.125:80 (Querying... ) (HTTP)
Local 192.168.1.80:55488 TIME-WAIT Remote 173.194.78.94:80 (Querying... ) (HTTP)
Local 192.168.1.80:55489 TIME-WAIT Remote 173.194.78.94:80 (Querying... ) (HTTP)
Local 192.168.1.80:55490 TIME-WAIT Remote 173.194.78.94:80 (Querying... ) (HTTP)
Local 192.168.1.80:55531 TIME-WAIT Remote 67.215.233.132:80 (Querying... ) (HTTP)
Local 192.168.1.80:55491 TIME-WAIT Remote 173.194.78.94:80 (Querying... ) (HTTP)
Local 192.168.1.80:55492 TIME-WAIT Remote 173.194.78.94:80 (Querying... ) (HTTP)
Local 192.168.1.80:55524 TIME-WAIT Remote 173.194.34.69:80 (Querying... ) (HTTP)
Local 192.168.1.80:55507 TIME-WAIT Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55506 TIME-WAIT Remote 173.194.34.64:80 (Querying... ) (HTTP)
Local 192.168.1.80:55393 TIME-WAIT Remote 213.120.161.202:80 (Querying... ) (HTTP)
Local 192.168.1.80:55536 TIME-WAIT Remote 94.127.74.120:80 (Querying... ) (HTTP)
Local 192.168.1.80:55537 TIME-WAIT Remote 94.127.74.120:80 (Querying... ) (HTTP)
Local 192.168.1.80:55538 TIME-WAIT Remote 94.127.74.120:80 (Querying... ) (HTTP)
System Process
Local 0.0.0.0:445 (Windows shares) LISTEN
Local 192.168.1.80:139 (NetBIOS session service) LISTEN
ccSvcHst.exe (1760)
Local 127.0.0.1:49508 LISTEN
lsass.exe (772)
Local 0.0.0.0:49156 LISTEN
services.exe (744)
Local 0.0.0.0:49157 LISTEN
svchost.exe (192)
Local 0.0.0.0:49154 LISTEN
svchost.exe (584)
Local 0.0.0.0:49153 LISTEN
svchost.exe (960)
Local 0.0.0.0:135 (DCE) LISTEN
wininit.exe (636)
Local 0.0.0.0:49152 LISTEN
I get this sometimes, have tried so much to stop it. At the point now where I just live with it to be honest. Although the 12.6 AMD driver has slowed it down a bit for me.
well it has but when you try live casting it bugs out the software so its a lot more annoying and noticeable.
Hmm, I had this issue a while ago turned out that my GPU overclock wasn't 100% stable. If you've overclocked your try reverting it to stock for a while.
Also, what brand / model is your PSU?
On a side note you're not getting the best out of your system given that you only have Win7 Home Premium and 32GB of RAM.
I also had problems like this with 12.4 and 12.6. Rolled back to 12.3 and bingo no BSOD and stable overclocks.
Probably worth a try before changing hardware.
http://www.********.co.uk/products/components/powersupplies/nov-psg600.html
thats my psu ... i started with 550w psu but then ppl said i prob didnt have enough so i upgraded to 600w what was avr apparently
Home Premium supports 16GB RAM at the most, you need Pro/Ultimate for more (up to 192GB), so half your memory is flapping in the wind
Also you can't post links or name competitors to OCUK. I deduce from the end of the URL that it is the PowerStation 600w? Probably a re branded OCZ/Sirfa, which is OK but idk
ah ok by the way i kinda started to see a pattern its mostly when i load a game or my broadcast tool something that is above small cpu ... mostly happens when i load my game but now and then happens when i exit / open a web browser.
Any idea what could be causing it ?
Mate, remove your Win install key from the spoiler text!
thanks! holy fudge balls i did not think it would record something that important into a text file T_T
also how do i turn off OC ? on the bios it only has the option to manual oc / auto oc and something els do i go manual and put them to 0 ?
