Sound output options (Telly to Amp)
5 Mar 2004
Southport
I've got a bit of an odd audio system in my playroom, I have a CD recorder plugged into my old (but awesome) Trio stereo amp, Into the CD recorder is the ouput from my PC (analogue phono) and I monitor it with the CD recorder which in turn feeds the amp...you still with me? good:)
My CD recorder has both coaxial and optical inputs left and I will soon be getting a Toshiba XV 37" telly it has both Optical and Analogue audio outputs, does the optical output still output a stereo signal so I can feed it into the CD recorder or do I need to use the Phono outputs in order to get a stereo signal?
Just realised the top part of this post is largely pointless:D
