- 7 Oct 2009
I’m using the onboard sound of my MSI Mag Tomahawk Motherboard.
l‘ve been using a creative 5300 5.1 speaker system which I can’t remember when I bought them but it was a long time ago!
Everything has been working fine until a few weeks ago when an intermittent sound problem has started happening. I can be happily using the computer and there will be a pop from the speakers and then the sound volume is really low. Turning the volume controls has no effect.
Sometimes after a while it will pop again and then start working normally.
Sometimes powering everything off and on will fix it, sometime not.
Sometimes unplugging all the speaker cables and reconnecting fixes it sometimes not.
So I’ve now been able to pin point what exactly fixes it other than it will work properly again at some point.
I don’t really know if its an issue with the onboard sound or the speakers, I’m suspecting the speakers due their age.
Anyone else had issues like this? Or offer any advice?
