I nearly always use a headset when gaming and speakers when I listen to music, so I have audio ports on the front of my case for that.
This is the first onboard soundcard that detects what I plug in and changes the settings accordingly.
Everything is connected right, however when I plug something in the front nothing is detected so basically they dont work. When I plug my headset into the port on the back of the PC, it thinks they are speakers so it sounds bloody awful when you turn it up and there is no bass. If you listen to something at a reasonably low volume its OK, but you turn it up a little and the bass is gone. It sounds like your listening to something out a surround sound system without the Sub.
I have fiddled witht he Vista sound controls and also with this Gigabyte audio panel with no such luck.
Im using a Sennheiser headset so it's definatley not that with the problem. It's virtually new and worked fine with my last board also with onboard audio.
Any ideas why i'm getting these problems?
