- 2 Mar 2007
The sound that my computer makes is disgusting so i thought id get a new case that is soundproof. I really like the look of the p180, or the Thermaltake VB1000BNS Soprano they bothe look really nice but i just wanted to know if any of the 2 actualy keep in the sound? or if there is any case out there that blocks sound and plus my current case vibrates a lot and i think that might be creating more sound. any suggestions?
P.s i was thinking of getting the Zalman CNPS9500-AM2 Aero Flower for my FX62 is it all that its hyped out to be?
Have you looked at changing your cpu cooler, quieter psu, hard drive enclosures, after market gpu cooler, quieter case fans. All of these will make the most difference regardless of what case you use. No case encloure will drown out noisy components. They will just help make the noise less obvious. Typically steel cases don't reverberate as much as aluminium ones, and some cases have thick side panels to help deaden noise or they might have a fancy way to suspend the hard drives so they don't vibrate. But I would say any case specifically designed for quiet computing is only going to contribute marginally to a quiet pc (maybe 10% at most) and these kind of cases are designed to be used with quiet components to begin with.
