I recently bought a Antec 300 to replace my CM Cav 3
& I have noticed a major noise increase caused of corse by :
> it being a tinner case
> having twice the fans
> having a mesh front instead of a 3mm thick door
btw my fans are :
120mm tri cool @ low
140mm ti cool @ med
2x120mm zalmans at front @ 900rpm
AC freezer pro @ 900rpm
4850 @ 36% fan speed.
Load are idle sound is the same
Roughly everything is at 20db
And it sits 2 feet away from me on my desk
But my question is how much of a difference does foam such as this make?
Is it worth it?
How many DB will it reduce the noise by?
btw my fans are :
140mm ti cool @ med
Is it worth it?
