Sound Recorder Problems on Sony Ericsson phones?
12 Jan 2004
Londinium
Im having problems with Sound Recorder on my w900i. Basically, if I insert a memory stick and try to record a sound using sound recorder, it will bomb out straight away and make an error tone sound. It also creates a small sound file on the memory stick, but it is unreadable. However, if I remove the memory stick, it works fine and records to the phones internal memory. The problem cant be the memory stick as recording photos or videos to it works fine, its just sound recorder tht doesnt like it!
After a bit of googling I can see that this problem can occur on many different SE phones, but have been unable to find a solution for it.
I have tried formatting the stick many times but it seems to have no effect.
Can anyone help?
