hey all,
so after lovingly gifting my brother the old computer he is kicking up a fuss about the noise it makes in his computer room.
The case sits on the desk next to the monitor and apprently the fans are way too noisy when gaming.
so was thinking that maybe some new fans would make the poor thing a little more barable. something like this:
2x sp120 for the h100i
http://www.overclockers.co.uk/showproduct.php?prodid=FG-016-CS
and 3x f12 pro for the case
http://www.overclockers.co.uk/showproduct.php?prodid=FG-037-AR
are these fans a fiarly good cost effective way to reduce sound in the case?
while looking into how to make the thing quieter, noticed that there are some people using foam in the case to try and reduce noise. is it worth the effort and does it make much difference?
pc current spec:
xclio nighthawk tower case, 3 stock fans. 2 front 1 rear. has a vented window too
i5 3570 @ 4.8ghz
h100i, 2 stock fans
MSI gtx 770 twinforzer 2gb, 2 fans but fairly quiet
250gb ssd
2 x 1tb hdd
pc current spec:
i5 3570 @ 4.8ghz
h100i, 2 stock fans
250gb ssd
2 x 1tb hdd
) and fitted them yesterday. kinda.
